Arts Web Site
Date:  6-10-2021
Brief Description:  Deburr RH elevator parts
I put away all of the LH elevator parts and diassembled the RH elevator. Before I took it all apart I marked the location of the ribs 1 thru 6 (inboard to outboard) so I could put them back in the same position when I rivet the assembly together later.
I had mostly deburred these parts a couple of years ago, but I went over them again to clean out the match drilled holes and a general check to see if I'd missed any rough edges. I had missed a couple of LH parts from before so I pulled them into this batch as well. I missed the hinge reinforcement plates, trim server support brackets and access door.
Deburred RH elevator parts ready for prep & prime
