Arts Web Site
Date:  7-15-2018
Number of Hours:  1.00
Brief Description:  Drilled Trim Tab Hinge and Trimmed Rear Spar
Just a small task completed today. The AN257-P2 piano hinge is used to create the E-01403 trim tab hinge. The hinge is undrilled, so it must be match drilled later in the plans to the trim tab spar and to the E-00907-1L rear spar. In this step, you only drill a hole on outboard side of both the forward and aft portions of the hinge. A #40 hole is drilled with 2D spacing (3/16 in).
I also trimmed the rear spar for the right side elevator.
Oshkosh next week! Can't wait!
A #40 hole is drilled on the outboard side of the hinge on each side.  This gets match drilled later.
