- Enlarged the hole in the oil cooler baffle to also expose the fitting where the oil return is to go.
- Cut out a large slot in the oil cooler baffle, with an integral fence at the back side, to deflect air down across the oil cooler (oil cooler not in photo #1).
- Installed the knob/cable for the cabin heat box. In photos 2 and 3 the knob is pulled out, and the flapper valve open, to allow warm air into the cabin.
