MURRAY'S WEB SITE
Spitfire Mk 26
Replace brake cylinders
Remove Supermarine brake cylinders and replace with used Cessna C172 cylinders.
Cut hole in port wing to access the ADAHRS. Dimple, prime and fit anchor nuts for access panel.
Swapped injector from #5 and #8 to verify #5 is running hot
Access hole for ADAHRS
Access panel primed
Spitfire mk 26 Home
Spitfire Mk 26 Home
1681
Equipment
1008
Insurance
Preparations
