Brief Description: Induction and final gear cycles
Welded extensions to transitions and throttle body and trimmed to fit.
Conducted final gear extension cycles and removed the jacks. Checked whell alignments and found atarboard side to be straight and port side minor toe-in.
Added 10 l fuel to check leak at tank. Observe no leaks after tightening fitting to drain line.
Re-installed induction components.
Add shim to tail wheel arm to make wheel vertical.
