Jacked up aircraft and attempt to cycle the port side MLG. Woiuld not fully retract and tripped circuit breaker.
Removed linear actuator and motor and determined actuator was too long by at least 25mm. Checked with Supermarine and confirmed the incorrect actuator had been provided.
Found that wheel would not fit into wheel well. Trimmed edge of wheel well to suit.
Ran the Dynon and input several parameters. It is showin only 4 cyl. Ran configuration toutine on Dynon.
