Soldered aircraft wite to switch and covered joints with heat shrinl. Fitted 12mm heat shring over switch threads and fit into collar snuggly.
Applied two layers of heat shring to wire at exit point and fixed in position with Sudal adhesive. Left a couple of meters of wire at exit point to cut later.
