MURRAY'S WEB SITE
Spitfire Mk 26
Door latch, trim cable holes
Drilled 1/16" hole with drill press in the door latch rod and assembled latch assembly. Does not work too smoothly.
Drilled 7/16" holes in the frame ring to accomodate the trim cable. Step drill on angle air drfill worked very well.
Drilled out 1/8" for the throttle and gear quadrants. Sanded off scatches.
Door latch
Spring end
Assembly for the trim cable holes
Spitfire mk 26 Home
Spitfire Mk 26 Home
1681
Equipment
1008
Insurance
Preparations
