Brief Description: Paint door reinforcement and inside of door.
Applied top coat to the door reinforcement and inside of door. Discovered that I had been using too low air pressure (was using 30 psi as per Develbiss). Lesonal recommends 45-60 psi. Applied the paint at thenhigher pressure with significantly better results. I suspect the Lesonal is much thicker than the zinc primer.
