Finished removing protective coating from the door reinforcement. Fastened in position with the top of the reinforcenment parallel to the bottom of the door. Re-drilled all 1/8" holes.
Clecoed throttle quadrant and gear quadrant into position. Both need more polishing.
Visited Peter Handbury to discuss drilling out the two rings to accomodate the trim cable. It appears to be necessary to drill a 1/2" hole in the rings to run the cable through. I plan to follow up with Supermarine before progressing.
