Diassembled joystick assembly. Removed rust with a wire wheel and buffed finished surfaces. Note - buffing the steel was not easily achieved.
Removed AN3 bolt from centre of main spar (Image 3) to allow the torque tube to be fitted parralel to belly skin. Installed bolt in the top hole of the spar.
