Brief Description: Asseembled port side centre section forward of the
Positioned top skin in place for the starbaord centre section forward of the main spar. Realised the spar had not beem countersunk for the top skins. Removed skin and countersunk all rivet holes on top of the spar, both port and starboard. Dimpled the the bottom of outer ribs. Installed 6 anchor nuts on the prt side outer rib.
Assembled ribsand forward spar on port side and positioned lower skin and doubler.
Fitted the retract arch to the starboard side, ready to rivet.
