Brief Description: Prepare port side centre section forward of main s
Removed port MLG pivot bracket and applied Duralac. Re-installed and torqued all bolts to 55 inch-lb.
Removed plastic protective coating from port side components. Very slow anddifficult to remove a lot of this coating. After soaking in keroscene for 48 hours, it was still very difficult to remove.
