Brief Description: Install shims on stiffeners and remove MLG axle ba
Rivet the shims to the stiffeners of the starboard centre section with 3-4 solid rivets. Finished riveting the ribs to the main spar. Also, the MLG aft bulkhead.
Need to check on rivet size. I maty have used the wrong length of rivet.
Removed the MLG and backing plates from main spar. Removed rust with a brass brush on the angle grinder. De-burr the bolt holes and trimmed off the rough edges of the holes in each plate.
