Dimpled the belly along the edge of the lower centre section skins. It was possible to reach inside the elevator control rod cover to place the lower die. All holes except the rear 2 were successfully dimpled using long handled needlenose pliers. The last hole on each side were not accessible due to them being immediatly below the aft spar.
I plan to use a 5/32" dome rivet for those two holes.
