Brief Description: Make new angles for starboard MLG bulkhead
Removed angles from the starboard MLG bulkhead and cut new lengths of 20mm x 25mm x 1.6 mm aluminum. Fitted bulkhead between ribs and clamped angles tobulkheadt. Moved ahead approximately 3/16"from original position at the top, drilled 3/32" holes and checked dimensions. Drilled out 1/8" and clecoed into position. Fitted lower skin and drilled out lower angle along the row of stringer holes. Did the same for the upper skin. Dimensions now look better as there is clearance along the bulkhead lower andgle for the stiffener rivets.
