Brief Description: Drill and cleco lower skin of starboard centresect
Completed match drilling 3/32" holes in the lower skin of the starboard centre section. Drilled all holes to 1/8" and clecoed. Removed clecos and set aside to prepare for etch priming.
Attempted to loosen bolts hold the port side landing gear motor bracket in place to allow clearance for the final rivet. Loosened all 4 nuts, but did not manage to get the bracket loosened.
