Robin's RV8 Web Site
Date:  5-7-2011
Number of Hours:  1.00
Brief Description:  Corrosion Treament
The metal is prepared with Scotch-Bright, washed with Deoxidine 624 and then treated with Alocrom 1200 two pack (MP0004). Finally, using a Devibis SRI HD Gravity fed spray gun with a 1.4 fluid tip. It is primed with a Sherwin-William’s two pack epoxy 2-Comp Chrome free epoxy (CM0481968) adding a reducer (10%). The reducer helps produce a silky finish. The process is all done within 24 hours to enable the paint to chemically bond with the Alocrom 1200 to give a very good scatch and chip resistance. The SRI Devilbis gun has an air input of 75psi and a gun pressure of 3.80bar as recorded on the gun's LED read out; it greatly helps in producing consistency.
The paint and metal is held at 17deg C for 24 hours with the humidity controlled prior to painting. A forced air system is used by the sprayer with full protection kit and a pair of old shoes. The atomised paint can adhere to anything even the paint surface of a car twenty yards away, my son knows to his cost. It did not come off! Everything was tried but the specks of paint never came off.
Prep. of  H. Stab parts
Alocrom 1200 H.Stab
Alocrom 1200 H.Stab
Chrome free epoxy primer
