The Redheads RV-7A Build SIte
Date:  7-27-2008
Manual Reference:  Section 6
Brief Description:  Priming the Empenage
I've been planning this stage for a while. Some weeks ago I went to Costo and bought 6 large plastic tarps with grommets to serve as the outer walls of a paint booth within my garage. I chose tarps that were blue on one side and silver on the other on the thought that having the silver side inside would make the most of whatever lighting I can put above the pait booth. I then assembled PVC pipes into a rectangular frame and hung them from the garage roof structure. I bought steel shower curtain rings and used them to hang the tarps from the PVC pipe frame. I made sure to to overlap the tarps one full grommet to keep any overspray within the paint booth.
I hung my cleaned parts from additional PVC pipe using safety wire. It's relaively cheap and shouldn't block paint from getting to the part.
Paint Booth in Garage Made From Plastic Tarps
Cleaned Empenage Parts Hanging in Paint Booth
Cleaned Rudder Skin Hanging in Paint Booth
