Conrads X-10 Build Log
Date: 1-2-2010
Number of Hours: 2.00
Manual Reference: 37-2 Steps 1 to 5
Brief Description: Section 37 FUEL SYSTEM page 37-2 Steps 1 to 5
Step 1, After coating the threads only with thread lube I installed the AN826-6D Tee into the lower part of the VA-178G Fuel Valve. Then I installed the two AN822-6D elbows and the ¼” plug as shown in figure 1.
Step 2, After locating the hardware called out for in figure 1 I installed the completed VA-178G Fuel Valve to the center tunnel F-1048C-1 Fuel Valve Bracket. Torque the bolts to 70 inch pounds.
Step 3, Pounded the VA-178A Fuel Handle Shaft with a brass hammer and scrap aluminum to protect the shaft into the VA-178G Fuel Valve and ten placing in the MS-35214-29 screw, AN960-6 washers and AN365-632A nut.
Step 4, I located the only AN837-6D 45 degree Elbow Bulkhead Fitting, AN spacer, and AN924-6D Nut to the F-1001 Firewall Bulkhead Assembly. Looking from the front I angled the nipple at about a 10 o’clock position.
Step 5, Now moving on to the F-1048 Fwd Fuselage Ribs I attached the AN833-6D 90 degree Elbow Bulkhead Fitting, AN aluminum spacer 6D washer, and AN924-6D Nut to the 1048 Fwd Fuselage.
Time about 2 hours
Installed the Completed VA-178G Fuel Valve
VA-178G Fuel Valve
Copyright © 2001-2025 Matronics. All Rights Reserved. |
