Craigs RV-8 Web Site
RV-8
Pitot Tube mount
finished up the mount for the pitot tube. Made and drilled an angle to rivet to the rib. the angle will stiffen the assembly. Drilled, Primed and dimpled all of the parts. Riveted the angle to the rib and the nutplates to the doubler.
Parts primed
Riveting the support angle on
final check of the fit
RV-8 Home
1476
Cowl
141
Engine Baffle
Fuel Tank
532
Fuselage Wiring
Induction system
Windscreen
247
