Dan's Web Site
Date:  8-18-2007
Number of Hours:  1.00
Brief Description:  Solder Second Ray Allen G205 Stick Grip
Today I soldered up the other Ray Allen G205 stick grip. There are several ways to wire these depending on whether you will be using one stick or two, a switch on the panel to activate one stick over the other, or if you will be using relays to control the switching action between the sticks. I went the relay route.
Solder the other Ray Allen G205 stick grip.
Both Ray Allen G205 stick grips ready to install.
