Brief Description: Vertical Power - Part 2 - Install
Once I had the bracket ready, installation of the Vertical Power system was simple and fast.
The unit hangs between the rear of the baggage compartment and the horizontal brace below the instrument stack. While the unit protrudes a little below the brace, it is well out of the way. Access for wiring will be very good while the skin is not installed. It will be pretty good later for maintenance.
Other builders have put the unit in the front baggage area, but I don't like the idea of giving up that space.
