![](/users/templates/images/spacer.gif)
Peters Web Site
![' style=](/users/templates/images/spacer.gif)
Date: 8-16-2023
Number of Hours: 3.00
Manual Reference: 9225501-LOG-07.095
Brief Description: Oil Cooler Fittings
I went straight to the hangar after work tonight, and decided to install the steel oil cooler fittings that arrived a couple weeks ago from Aircraft Spruce. I was advised by two different LAME's to replace the standard alloy fittings with steel ones, for ongoing durability and peace of mind.
So, I spent three hours at the hangar tonight, and all I got done was installation of two fluid fittings on the back of the engine. The "easy" one took an hour, the other one took two hours. I had to mangle another spanner, plus come up with a ridiculous socket concoction, in my efforts to do them up. There's simply no space.
Anyway, I got there in the end, so job done.
I'm still waiting for the two steel fittings that go at the oil cooler end. They're still on backorder.
This was the easy one
Not so easy
Well, at least the hard part is now done
