Chris's RV-14A Site
Date:  6-19-2016
Number of Hours:  4.00
Brief Description:  Install the J channel stiffener in laft tank
Installed the left tank stiffener. Butter it up with tank sealant and then buck the rivets. Once the rivets are set you need to cover the shop heads with sealant. I added a small filet of sealant to the channel edges to make sure there are no leaks here. Also finished riveting in the tank attach brackt to the end of the tank.
Tank stiffener
Tank stiffener
Tank attach bracket
Tank attach bracket
