Brief Description: Adjust and Tighten All Exhaust Supports / Hardware
After making some final adjustments to make sure everything was symmetrical from all sides I tightened all of the exhaust support hardware. The only thing left to do is install the EGT probes.
To prevent moisture and anything else from entering the cylinders I covered the ends of the tail pipes with duct tape.
Tail pipes as viewed from the belly looking forward
