Since I had so much success on the 3D tube bending, this would be a piece of cake. All the bends are in one plane...no problem, I got this. It turned out great...look honey, see how well it matches the drawing. Let me go add the flare and I'll be done. Just as I started to crank down on the flare I remembered...shouldn't I have the fitting (AN818-6D) slide on before I flare...too late. The picture included is round 2, where I remembered to slide the fitting on first. Good thing I ordered extra tubing a long time ago. With the busing installed, the fit is real tights. I have to slide the tank in to get it connected, which is real tricky.
