Brief Description: Installed Pitot Tube & Control Cables in Left Wing
I preparation for covering the top of the left wing I installed the tubing for the pitot system using two Adel clamps. I ran the tubing through the hole I previously drilled in the rear wing spar and ran it out the inboard end of the spar.
I installed the aileron and flap control cables. I did not install the pulleys. I zip tied the thimbles to the pulley brackets.
