Positioned the pedals in the most forward position and hope that this is the best choice. Time will tell. I ordered dual brakes but received dual pedals but not the second set of brake cylinders. Hopefully ICP will correct this. Installed also the steering wheel rods which fitted perfectly. Also installed the rudder control cables which was easy as the cables were pre-manufactured and only needed attachments to the pedals. Attachment to the rudder will await.
