Continued working on the static system. I managed to break a T connector for the static line, so I will be looking locally for a replacement. I found one that might work. I should have taken pictures but did not.
The static line runs under the longeron to the front of the aircraft. There are a few long runs without support so I fabricated two clips to support the line. The second image shows the clip on the line. It is too long, I just wanted to ensure it would work.
