Davids Web Site
Work Logs Found: 94
Category Work Time: 660 Hours
 Date
Hours
Work Log Summary
Details
 06-29-2014
5.00
Bonding the plexi glass to the canopy frame
Details
 06-28-2014
4.00
Prep for bonding the canopy
Details
 03-04-2014
4.00
Sliding canopy frame
Details
 03-03-2014
4.00
Sliding canopy
Details
 02-16-2014
6.00
Windscreen
Details
 04-30-2013
8.00
Canopy plexiglass cutting
Details
 04-29-2013
6.00
Static System
Details
 04-28-2013
5.00
Elevator Trim Servo
Details
 02-28-2013
10.00
Starter solenoid/master relay, cabin side channels
Details
 02-21-2013
10.00
Battery box, Master relay, Starter solenoid
Details
 02-13-2013
10.00
Rudder stops, battery box
Details
 02-07-2013
8.00
Elevator Rigging
Details
 08-28-2012
8.00
Rudder control cables
Details
 08-21-2012
16.00
Mounting tail surfaces
Details
 07-25-2012
8.00
Tail to Fuselage Mounting
Details
 07-18-2012
3.00
Throttle, Mixture, Carb heat controls
Details
 07-17-2012
10.00
Sub-panel, eyeball vents, heater box
Details
 07-03-2012
8.00
Flight controls
Details
 06-12-2012
8.00
Brakes, Fuel vent line, Instrument panel
Details
 06-07-2012
5.00
Assembly Forward fuselage
Details
 06-07-2012
0.00
6/7/12 Continued
Details
 06-05-2012
5.00
Center tunnel/brakes
Details
 06-04-2012
4.00
Firewall doublers
Details
 05-29-2012
9.00
Paint....lots of paint
Details
 05-23-2012
4.00
Center tunnel cover
Details
 05-22-2012
8.00
Fuel line/center tunnel
Details
 05-16-2012
10.00
Fuel Selector Valve
Details
 05-09-2012
4.00
Fuel Pump, Gascolator
Details
 05-08-2012
25.00
brakes, rudder pedals, fuel vent lines
Details
 05-07-2012
25.00
Etch, alodine, prime, assemble
Details
 02-21-2012
3.00
NACA Scoops
Details
 02-15-2012
F-6111 Skin Stiffeners
Details
 02-07-2012
8.00
Canopy frame slide, stiffening channel, skin gusse
Details
 01-17-2012
4.00
Roll bar
Details
 01-16-2012
5.00
Roll bar/canopy frame
Details
 01-09-2012
6.00
Fwd Fuselage Skin
Details
 01-05-2012
Forward/upper skin
Details
 01-04-2012
4.00
Instrument panel
Details
 12-28-2011
5.00
Roll bar brace
Details
 12-27-2011
5.00
Instrument panel/Fwd fuselage structure
Details
 12-26-2011
10.00
Canopy Deck
Details
 12-19-2011
6.00
Fwd/Upper Fuselage Structure
Details
 12-17-2011
12.00
Flap Actuator Enclosure
Details
 09-10-2011
8.00
Pilot/Co Pilot Seat Backs
Details
 08-28-2011
3.50
Pilots seat back
Details
 08-27-2011
3.50
F656L and Shoulder harness cutouts
Details
 08-20-2011
5.50
Aft baggage panels and nutplates, F656R
Details
 08-13-2011
7.00
Cabin and baggage floor panels
Details
 07-31-2011
8.00
Converted fuselage jig
Details
 07-09-2011
6.00
Floor nutplates/baggage bulkhead
Details
 07-03-2011
7.00
Floor panel nutplates
Details
 06-25-2011
8.50
F674,F675 Skins
Details
 06-10-2011
7.50
Aft deck attaching parts
Details
 06-08-2011
3.00
Aft deck
Details
 03-26-2011
24.00
Riveting fuselage
Details
 03-24-2011
18.00
Floor panels
Details
 03-12-2011
8.00
Reassembly
Details
 02-12-2011
3.00
Fwd Fuselage Structure
Details
 02-05-2011
12.00
Reassembly
Details
 01-14-2011
5.00
Prep and prime skins
Details
 01-08-2011
3.00
Prime skins
Details
 01-07-2011
Prep skins
Details
 12-19-2010
3.00
Prime skins
Details
 12-11-2010
4.00
Prep skins
Details
 11-30-2010
5.00
Dimple skins
Details
 11-27-2010
35.00
Treat and prime fuselage parts
Details
 10-14-2010
3.00
Fuselage disassembly
Details
 09-30-2010
4.50
Fuselage structure
Details
 09-30-2010
4.50
Forward skin F672
Details
 08-29-2010
6.00
Fuselage bottom skins
Details
 08-21-2010
12.00
Fuselage side skins
Details
 08-01-2010
5.50
Tail cone bottom skin
Details
 07-27-2010
3.50
Tail side skins
Details
 07-26-2010
5.00
Tail cone side skins
Details
 07-24-2010
2.50
Aft/lower tail skin
Details
 07-22-2010
6.00
Tail cone stringers
Details
 07-16-2010
3.00
Arm rests
Details
 07-08-2010
7.00
Baggage floor ribs
Details
 07-07-2010
3.50
Cabin floor ribs
Details
 07-02-2010
3.00
Cockpit floor ribs
Details
 06-26-2010
Tail wheel weldment.
Details
 06-17-2010
6.00
Fuselage structure
Details
 06-07-2010
6.00
Fuselage frames
Details
 06-06-2010
4.00
Fuselage frames
Details
 06-04-2010
6.00
Fuselage frames
Details
 05-31-2010
3.00
Longerons
Details
 05-23-2010
5.00
F605 3
Details
 05-22-2010
5.00
F605 2
Details
 05-21-2010
8.00
F605 Bulkhead
Details
 05-20-2010
10.00
F604 Bulkhead
Details
 05-19-2010
8.00
Firewall 3
Details
 05-18-2010
8.00
Firewall 2
Details
 05-15-2010
8.00
Firewall
Details
 05-10-2010
10.00
Fuselage Fixture
Details
