Terrences Web Site
Work Logs Found: 63
Category Work Time: 213 Hours
 Date
Hours
Work Log Summary
Details
 03-01-2019
4.00
Drill 1/4" and 5/16" holes in doublers/angles
Details
 02-25-2019
4.00
Drill Seat Front Angle and Rear Bottom Angle to ce
Details
 02-22-2019
6.00
Drill front section of Center Spar for 3/16" Rivet
Details
 02-18-2019
3.00
Disassemble center spar for upgrade--rear
Details
 02-17-2019
3.00
Details
 02-11-2019
6.00
Details
 03-29-2017
5.00
Rivets Spar Caps and Doubler to Spar
Details
 03-23-2017
6.00
Rivet doubler to web, shims, and front rib attach
Details
 03-16-2017
Fill misdrilled 3/32" holes in web and doubler wit
Details
 03-10-2017
3.00
Disassemble, deburr, scour, clean, and prime left
Details
 02-16-2015
3.00
Drill holes to attach left spar NR#1 to rib angles
Details
 02-15-2015
4.00
Drill nose rib anges for left spar NR#2, and NR#1
Details
 02-10-2015
6.00
Left spar prep for nose ribs
Details
 12-08-2012
8.00
Project Restart: Logging work done in 2012
Details
 12-06-2012
3.00
Practice oval cut in .040 & remove rivets
Details
 12-05-2012
3.00
Riveted the doubler to the right wing spar
Details
 12-01-2012
Prime Right Spar Doubler Parts
Details
 11-30-2012
4.00
Prepare doubler for right wing spar
Details
 02-24-2012
3.00
Blend out damage to L-bottom spar cap
Details
 05-29-2011
4.00
Reassemble left aileron w/ balance & hinge
Details
 05-28-2011
8.00
Continued.: balance arm & piano hinge
Details
 05-26-2011
8.00
Install balance arm & piano hinge on right aileron
Details
 02-17-2011
Reinstall aileron trim servo
Details
 02-11-2011
4.00
Deburr, scour, clean, and prime new aileron joints
Details
 01-22-2011
6.00
R aileron piano hinge conversion
Details
 01-16-2011
Revised mod process for right aileron
Details
 01-15-2011
Drill piano hinge attach holes to #30
Details
 01-05-2011
Drill inboard rib for left aileron counterbalance
Details
 11-13-2010
Drill out gussets for L-aileron
Details
 11-10-2010
5.00
Pilot drill L-aileron to hinge
Details
 11-07-2010
5.00
Prepare & pilot drill L Aileron for piano hinge
Details
 11-04-2010
Add L-angle back doubler behind aileron horn
Details
 11-03-2010
5.00
Mod left aileron to accept counter balance
Details
 10-25-2010
Disassemble left aileron to install balance, Hinge
Details
 10-21-2010
5.00
Drill & ream holes for left spar root doubler plat
Details
 08-13-2010
Remove web doubler from right spar
Details
 08-07-2010
Left spar cap rivet removal: bottom root
Details
 08-06-2010
3.00
Rivet the left top spar cap back together
Details
 08-06-2010
Confer with Zenair Re bend in R Spar at doubler
Details
 08-02-2010
3.00
Drill extra hole for AN3 bolt in extrusion & prime
Details
 07-29-2010
Back drill rivet holes through the spar cap extrus
Details
 07-23-2010
0.10
Remove rivets--continuation
Details
 07-23-2010
5.00
Remove rivets from left spar cap
Details
 07-21-2010
4.00
Drill wing attach 5/16 bolt holes to fit NAS bolts
Details
 07-09-2010
3.00
Drill the holes in the wing root doubler to final
Details
 07-03-2010
Replace one rivet
Details
 07-02-2010
3.00
Rivet spar web doubler in place
Details
 07-01-2010
Drill doubler and spar web, prepare for riveting
Details
 06-27-2010
5.00
De-rivet spar caps inboard & install web doubler
Details
 05-28-2010
Transfer punch & pilot drill holes in spar root do
Details
 05-27-2010
3.00
Rivet & bolt extrusion to right wing spar cap
Details
 05-26-2010
Set up work bench to rivet extruded angle to spar
Details
 05-24-2010
Deburr, scour, clean, and prime top spar cap joint
Details
 05-21-2010
0.01
Practice 3/16" Solid Riveting (cont.)
Details
 05-21-2010
Details
 05-04-2010
3.00
Remove bottom spar cap rivets & nose rib angles
Details
 03-24-2010
3.00
Drill spar cap extruded angle for rivets
Details
 03-23-2010
Position extruded angle for drilling
Details
 03-23-2010
3.00
Cut off spar cap angle and clean up spar cap
Details
 03-20-2010
Remove solid rivets from spar 2/2
Details
 03-20-2010
7.00
Remove solid rivets from spar 1/2
Details
 03-19-2010
Drill solid rivet heads on R wing spar
Details
 03-18-2010
8.00
Build jig to support main spar for riveting
Details
