Michaels Web Site
Sonex Standard Gear
Work Logs Found:
100
Category Work Time:
179 Hours
Date
Hours
Work Log Summary
Details
01-07-2012
4.25
Tail fairings complete
Details
01-02-2012
0.25
Tail fillets
Details
12-29-2011
Rudder hinge, stops & fillets
Details
12-29-2011
0.00
Misc shots of project to date
Details
12-28-2011
Secure vertical stab bolts
Details
12-27-2011
0.00
Vertical stabilizer tail post
Details
12-27-2011
3.50
Bolting down vertical tail
Details
12-26-2011
1.25
Vertical stabilizer attachment
Details
12-26-2011
1.75
Secure horizontal stab
Details
12-23-2011
1.75
Fit horizontal stabilizer
Details
12-21-2011
0.50
Deburring tail holes
Details
12-19-2011
2.25
Horizontal Tail Attach
Details
12-18-2011
0.00
Details
06-12-2011
2.50
RIGHT horiz tail tip installation
Details
06-11-2011
4.50
Horiz tail tip installation
Details
06-11-2011
0.00
Details
06-09-2011
LEFT horiz tail tip installation
Details
06-08-2011
1.25
Details
06-07-2011
Horiz tail tips
Details
03-12-2011
1.50
Vertical tail tip
Details
03-09-2011
0.75
Vertical tail tip
Details
03-08-2011
1.50
Vertical tail tip
Details
03-08-2011
0.00
Vertical tail tip
Details
03-08-2011
0.00
Vertical tail tip
Details
03-07-2011
2.50
Vertical tail tip
Details
03-07-2011
0.00
Vertical tail tip
Details
03-06-2011
Tail tip ponderings
Details
01-11-2011
3.25
FINISHED THE RUDDER!
Details
01-10-2011
2.50
Rudder hing layout and drilling
Details
01-08-2011
2.50
Drilled rudder for all ribs
Details
01-07-2011
1.25
Holes in rudder skin for ribs
Details
01-05-2011
Cut outs in rudder
Details
01-04-2011
Bent rudder skin
Details
12-02-2010
0.50
T13 Rudder skin
Details
09-18-2010
0.50
Trim tab; Finished T02
Details
09-16-2010
0.00
FINISHED the elevators!
Details
09-16-2010
1.25
Details
09-15-2010
3.00
Deburr & rivet elevator skins
Details
09-14-2010
1.50
Updrilling & deburring elevators
Details
09-13-2010
2.75
Elevator hinges & updrilling
Details
09-12-2010
1.75
Elevator hinges
Details
09-11-2010
1.50
Finished elevator horn
Details
09-11-2010
1.50
Attached elevator horn assembly
Details
09-10-2010
2.75
Elevators + Elevator Horn
Details
09-09-2010
2.50
Right, then back to left, elevator
Details
09-08-2010
2.25
Right elevator
Details
09-07-2010
Left elevator
Details
09-06-2010
Trim tab & elevator hinges
Details
09-06-2010
2.50
Elevators
Details
09-01-2010
1.50
Elevator skins & trim tab
Details
08-31-2010
0.75
Finished 1st elevator skin; started next
Details
08-30-2010
1.75
Bent then cut 2nd elevator skin
Details
08-29-2010
1.75
Bent the first elevator skin
Details
08-26-2010
1.75
Elevator skins
Details
04-06-2010
2.75
Horiz and vert stabs
Details
04-05-2010
4.00
Continued skinning horiz stab
Details
04-04-2010
1.50
Continued 2nd skin of horiz stab
Details
04-03-2010
Started on 2nd skin of horiz stab
Details
04-02-2010
Finished riveting 1st skin of horiz stab
Details
04-01-2010
3.00
Updrilled holes in 1st horiz stab skin
Details
03-31-2010
2.50
Started skinning the horizontal stabilizer
Details
03-29-2010
1.50
Rivets on 2nd side of vert stab
Details
03-28-2010
4.75
Started skinning the vert stab
Details
03-28-2010
0.00
Photos of vert tail skinning
Details
03-28-2010
0.00
Details
03-28-2010
0.00
Details
03-27-2010
3.00
Finished framing of horiz stab
Details
03-26-2010
3.50
Finished vert stab framing (mostly)
Details
03-24-2010
1.25
Started drilling vert stab
Details
03-23-2010
3.00
Layout of vert stab
Details
03-21-2010
1.25
T13-02 Rudder drive horn assembly
Details
03-21-2010
Finished T09-01 vert stab main spar
Details
03-20-2010
3.00
Continued main spar of vert stab
Details
03-20-2010
2.50
Continued main spar ass'y of the vertical stab
Details
03-19-2010
2.75
Forward spar of vert stab
Details
03-10-2010
1.50
Deburred & riveted Horiz Stab ribs
Details
03-09-2010
3.00
Continued with Horiz Stab
Details
03-08-2010
2.50
Horiz stab ribs
Details
03-07-2010
2.50
Finished main spar assembly of horiz stab
Details
03-06-2010
3.00
Horiz stab, front spar ass'y
Details
03-06-2010
2.50
Forward and Main Horiz Stab Assemblies
Details
03-05-2010
3.25
Started BUILDING horiz stabilizer
Details
03-02-2010
0.75
2 channels for tail
Details
03-01-2010
Bending tail channels
Details
02-28-2010
2.25
Bending channels for the tail
Details
02-01-2010
2.75
Channels for tail & fuselage + wing nose rib
Details
01-31-2010
Lay out channels for horiz stab
Details
01-23-2010
3.00
Tail and Fuselage Channels
Details
01-22-2010
0.00
#3 Final photos of channel bending process
01-22-2010
0.00
#2 More photos of channel bending process
01-22-2010
1.75
#1 Creating channels
Details
01-05-2010
1.50
Wing & Tail Parts
Details
01-04-2010
0.75
T05-01 L
Details
01-02-2010
4.00
Finished 2 empanage skins
Details
01-01-2010
4.75
Empenage skins
Details
12-29-2009
0.50
Prepped for empenage skins
Details
12-28-2009
0.50
Fluted tail ribs
Details
12-18-2009
3.00
Empenage Ribs
Details
12-11-2009
Bent tail ribs
Details
12-08-2009
0.50
Deburring .025 parts
Details
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
