Buck's RV-8
Work Logs Found: 298
Category Work Time: 656 Hours
 Date
Hours
Work Log Summary
Details
 08-24-2015
2.20
Throttle arm modification, control-fit
Details
 01-28-2015
Fuel vents
Details
 01-25-2015
0.80
Wing root fairings
Details
 01-18-2015
1.10
Flaps-up microswitch installation
Details
 01-18-2015
3.20
Flap fairings; fuel selector cover, NACA scoop
Details
 01-13-2015
1.30
L flap fairing; traffic watch antenna; misc.
Details
 01-06-2015
5.50
Forward spar attachments
Details
 01-02-2015
0.50
Hole removal
Details
 12-28-2014
1.10
Flap rods
Details
 12-21-2014
4.60
Flap rods and rod holes
Details
 11-18-2014
Refabricated lower side panels
Details
 09-17-2014
1.10
Removed tail camera wiring
Details
 11-05-2013
1.80
Rear baggage floor revision
Details
 11-04-2013
0.90
Details
 11-03-2013
1.10
Details
 11-02-2013
2.10
Details
 05-09-2011
4.10
Flight controls; wingtip wiring connector
Details
 01-28-2011
4.10
Throttle quadrant; front seat support re-install
Details
 01-26-2011
2.50
Wiring prep; brake lines
Details
 01-19-2011
4.50
Fuel lines
Details
 01-13-2011
4.00
Fuel lines
Details
 01-10-2011
5.20
Fuel lines; front seat support bar; wing pins
Details
 01-09-2011
5.00
Fuel lines; left brake line
Details
 12-01-2010
0.50
Canopy center rail
Details
 11-22-2010
0.30
Canopy center rail
Details
 11-05-2010
Canopy rail; wiring prep
Details
 11-04-2010
2.50
Brake lines; wiring clamps; wiring
Details
 11-03-2010
3.60
RV-8 conversion bolts
Details
 06-06-2010
1.50
DVR Mount
Details
 06-05-2010
8.10
Elevator bellcrank access hatch
Details
 10-03-2009
Details
 09-22-2009
1.20
DVR mount
Details
 09-11-2009
2.10
DVR mounting platenuts; circuit breaker plate
Details
 09-07-2009
DVR mount and wiring cover plate
Details
 09-06-2009
3.10
Remove false spars; stick well cover; DVR mount
Details
 09-05-2009
2.50
Attach landing gear (final)
Details
 09-04-2009
2.50
Details
 08-29-2009
1.10
Rear cockpit stick well cover
Details
 08-24-2009
4.00
Main switch panel work; gear bolts
Details
 08-23-2009
Gear bolts
Details
 08-22-2009
1.50
Magnetometer shelf modification
Details
 08-19-2009
0.20
Anodized canopy rails
Details
 08-15-2009
3.00
Attach landing gear
Details
 08-14-2009
3.50
Attach landing gear
Details
 08-10-2009
3.60
Attach landing gear
Details
 07-22-2009
2.30
Attach horizontal stablizer; attach vertical stab
Details
 07-20-2009
4.00
Aft bulkhead; AHRS mount; empennage prep
Details
 07-19-2009
3.10
Tail wiring; aft bulkhead
Details
 07-17-2009
1.10
Upper-right map pocket
Details
 07-16-2009
3.00
Main switch console; map pocket
Details
 07-15-2009
3.10
Map pocket; tail conduit mount
Details
 07-14-2009
1.20
Alternator controller; map pockets
Details
 07-11-2009
3.90
Cockpit / panel planning
Details
 07-08-2009
1.50
Map pocket
Details
 07-06-2009
2.40
Map light mount; map pockets; misc.
Details
 07-02-2009
2.20
Mid-cabin cover; ELT antenna mount
Details
 06-29-2009
1.50
Wiring prep; gear brake line fittings
Details
 06-22-2009
1.10
Cooling ramp: vibration-deadening mats
Details
 06-18-2009
1.60
Conduit standoffs; access cover painting
Details
 06-15-2009
Access covers; rear cockpit power port; transducer
Details
 06-14-2009
5.40
Fuel flow transducer; wiring conduit; elev. stop
Details
 06-13-2009
3.10
Rear fuselage conduit
Details
 06-13-2009
Fuel flow transducer mount
Details
 06-12-2009
1.30
Prime and paint aft deck
Details
 06-12-2009
3.80
Details
 06-11-2009
2.25
Gear leg priming and hardware assembly
Details
 06-07-2009
2.30
Left wheel, left gear leg
Details
 06-05-2009
2.10
Tires and tubes
Details
 05-30-2009
1.40
Fuel flow transducer plumbing
Details
 05-29-2009
0.50
Tail wiring
Details
 05-28-2009
0.50
Details
 05-14-2009
0.90
Front seat support bar; firewall straightening
Details
 05-10-2009
0.70
Details
 05-09-2009
Firewall passthrough, firewall straightening
Details
 05-04-2009
1.40
Forward skin
Details
 05-03-2009
3.50
Forward fuselage skin
Details
 05-02-2009
0.30
Aft bulkhead stiffener ring
Details
 05-01-2009
2.10
Aft canopy slide rail; side rails
Details
 04-28-2009
2.30
Details
 04-27-2009
1.80
Details
 04-16-2009
1.90
Forward skin
Details
 04-15-2009
1.20
Smoke oil line
Details
 04-10-2009
2.90
Cabin heat valve; instrument panel mount
Details
 04-08-2009
2.20
Details
 04-07-2009
3.80
Details
 04-06-2009
3.40
Details
 04-05-2009
2.80
Fuel line; forward skin; brake lines
Details
 04-04-2009
Brake lines
Details
 04-03-2009
2.50
Fuel lines
Details
 04-03-2009
Brake lines
Details
 04-02-2009
2.20
Fuel lines; air vent bulkhead fitting
Details
 04-02-2009
2.40
Brake lines (prep work)
Details
 04-01-2009
4.60
Brake lines; fuel lines
Details
 03-29-2009
4.00
Fuel lines; parking brake deletion
Details
 03-25-2009
0.70
Fuel pump mount
Details
 03-20-2009
1.80
Brake lines; fuel vent lines
Details
 03-18-2009
Engine mount attachment
Details
 03-18-2009
2.90
Aft bulkhead fabrication
Details
 03-17-2009
Rudder pedal assembly shims/wear-strips
Details
 03-14-2009
2.40
Details
 03-05-2009
Mid-cabin cover
Details
 02-10-2009
2.20
Details
 11-06-2008
Strobe pack; static line; switch panel angle
Details
 11-05-2008
1.10
Strobe pack and ELT mounts
Details
 11-04-2008
Strobe pack mount
Details
 11-03-2008
1.50
Strobe pack mount
Details
 10-23-2008
Strobe pack mount
Details
 10-22-2008
2.80
Rudder pedals; battery box; engine mount
Details
 10-21-2008
0.50
Tailwheel attachment
Details
 10-19-2008
1.30
APRS system; fuel selector
Details
 10-17-2008
0.40
Pedal assembly
Details
 10-16-2008
0.40
Paint misc components; strobe mount
Details
 10-06-2008
0.80
Battery box mounting
Details
 10-02-2008
Battery box
Details
 09-30-2008
0.60
Battery box
Details
 09-24-2008
0.70
Battery box; strobe pack mount
Details
 09-23-2008
1.60
Battery box
Details
 09-05-2008
5.10
Battery box modifications and installation
Details
 09-03-2008
0.40
Battery box; systems re-installation
Details
 09-02-2008
1.30
Battery box; interior paint touchups
Details
 09-01-2008
2.50
Battery box; avionics access door
Details
 08-31-2008
1.10
Miscellaneous painting
Details
 08-30-2008
Interior painting; battery box and holddown bar
Details
 08-29-2008
Interior prep/prime
Details
 08-21-2008
0.80
Battery box
Details
 08-20-2008
5.10
Paint stripping
Details
 08-19-2008
2.40
Static line, smoke oil line
Details
 08-17-2008
0.70
Battery box
Details
 08-16-2008
1.40
Battery box
Details
 08-13-2008
Avionics access door
Details
 08-12-2008
0.40
Details
 08-09-2008
Details
 08-05-2008
Details
 07-15-2008
1.10
Foward baggage modification; electrical busses
Details
 07-12-2008
1.50
Forward baggage compartment modification
Details
 07-11-2008
2.40
Details
 07-08-2008
2.20
Details
 07-07-2008
4.50
Systems installation (flaps, servos); svc bulletin
Details
 07-05-2008
4.00
Systems installation; painting
Details
 07-02-2008
2.30
Details
 07-01-2008
5.70
Wing attach fittings; landing gear; interior paint
Details
 06-30-2008
5.50
Landing gear
Details
 06-29-2008
4.90
Landing gear
Details
 06-28-2008
5.50
Landing gear
Details
 06-27-2008
Landing gear
Details
 06-26-2008
0.50
Landing gear
Details
 06-25-2008
0.70
Interior painting
Details
 06-22-2008
0.50
Interior painting
Details
 06-21-2008
0.80
Interior painting
Details
 06-18-2008
5.00
Interior painting
Details
 06-17-2008
4.80
Interior paint prep; NACA scoop
Details
 06-16-2008
3.50
NACA scoop; interior painting prep
Details
 06-15-2008
3.00
Avionics access door; interior painting prep
Details
 06-14-2008
2.20
Cable fairing; avionics access door; paint prep.
Details
 06-08-2008
1.10
VS attach plate; EFIS backup battery jack
Details
 06-07-2008
2.10
Tail cleanup; EIS mounting hole; misc.
Details
 06-06-2008
1.40
Elevator horn drilling; tail removal
Details
 06-04-2008
Details
 06-02-2008
1.80
Avionics access door; brake return springs
Details
 05-28-2008
Pedal tension springs
Details
 05-27-2008
0.70
Rudder cable fairings
Details
 05-26-2008
2.10
Rudder stops and cables
Details
 05-24-2008
1.20
Rudder pedals, cables and stops
Details
 05-22-2008
1.80
Rudder cables and pedals
Details
 05-21-2008
2.20
Elevator controls
Details
 05-20-2008
2.10
Elevator and rudder mounting
Details
 05-19-2008
1.80
Elevator mounting
Details
 05-18-2008
1.20
Elevator mounting
Details
 05-12-2008
Elevator mounting
Details
 05-10-2008
3.30
Flight controls
Details
 05-05-2008
1.10
Battery mount
Details
 04-23-2008
3.10
Avionics planning; horizontal stab mounting
Details
 04-22-2008
1.80
Fuel filter; finish kit inventory
Details
 04-19-2008
Electric fuel pump; air vent scat tubing
Details
 04-17-2008
1.10
FINISH KIT DELIVERY; Battery charger jack
Details
 04-16-2008
1.30
Floorboards; interior painting prep
Details
 04-15-2008
1.70
Floorboard platenuts; miscellaneous stuff
Details
 04-14-2008
3.20
Aileron trim; autopilot servo; gear leg prep
Details
 04-10-2008
2.20
Rudder pedals; aileron trim
Details
 04-09-2008
3.00
Rudder pedals, aileron trim
Details
 04-08-2008
2.40
Flap microswitches
Details
 04-06-2008
2.50
Rudder pedals; flap limit switches
Details
 03-29-2008
Baggage door; fuselage platenuts; pedal assy.
Details
 03-23-2008
2.10
Avionics access door; rudder pedals
Details
 03-22-2008
0.80
Details
 03-16-2008
2.40
Rudder pedals and brakes
Details
 03-10-2008
0.30
Rudder pedals
Details
 03-05-2008
1.70
Rudder pedals
Details
 02-16-2008
1.50
Avionics access door, rear cockpit map light
Details
 01-28-2008
5.50
Avionics access door; rear cockpit map light
Details
 01-16-2008
3.10
Front seat; side console; rear seat map light
Details
 01-15-2008
3.20
Seat attach platenuts; flap microswitches
Details
 01-10-2008
1.50
Front seat; smoke system
Details
 01-07-2008
3.40
Gear tower bolts; mid-cabin covers
Details
 11-30-2007
1.80
Fuel selector; power outlet; headphone jacks
Details
 11-29-2007
2.30
Rear seat throttle; fuel selector
Details
 11-28-2007
5.50
Fuel selector
Details
 11-27-2007
3.30
Rear seat throttle
Details
 11-26-2007
1.60
Rear seat throttle; misc. shop stuff
Details
 11-15-2007
3.10
Rear seat throttle
Details
 11-09-2007
3.30
Rear seat throttle
Details
 11-08-2007
6.20
Front seat; rollover bar; mid-cabin covers; pedals
Details
 11-07-2007
4.50
Front seat; rear seat
Details
 11-06-2007
4.00
Details
 11-05-2007
4.50
Front seat
Details
 11-02-2007
4.80
Roll bar; seats; rudder pedals
Details
 10-30-2007
5.70
Roll bar; rear seat; rudder pedals
Details
 10-29-2007
2.90
Flap shaft cover; rudder pedal extensions
Details
 10-28-2007
5.10
Flap shaft cover; elev. pushrod & bellcrank mount
Details
 10-25-2007
2.40
Pedal access hatch
Details
 10-24-2007
4.80
Pedal access hatch
Details
 10-23-2007
5.20
Pedal access hatch
Details
 10-23-2007
0.40
Flap rods
Details
 10-20-2007
0.50
Pedal access hatch
Details
 10-18-2007
0.50
Pedal access hatch; elevator pushrod
Details
 10-16-2007
1.30
Large elevator pushrod
Details
 10-15-2007
3.30
Smoke system; elevator pushrods; control stick
Details
 10-10-2007
1.10
Smoke system
Details
 10-09-2007
Smoke system
Details
 10-08-2007
1.50
Elevator pushrods; smoke system
Details
 10-04-2007
0.50
Smoke system
Details
 10-03-2007
2.80
Smoke system; elevator bellcrank
Details
 10-02-2007
2.10
Avionics access door; smoke system
Details
 10-01-2007
3.30
Details
 09-30-2007
0.60
Static ports and lines
Details
 09-30-2007
3.70
Elevator bellcrank attach angles
Details
 09-29-2007
1.90
Autopilot pitch servo mount; elevator bellcrank
Details
 09-28-2007
0.30
Remote compass mount
Details
 09-27-2007
2.40
Details
 09-26-2007
2.80
Remote compass mount; elevator bellcrank
Details
 09-25-2007
1.80
Elevator bellcrank; interior paint tests
Details
 09-24-2007
3.10
ELT mount; strobe mount; static ports/lines
Details
 09-23-2007
4.50
Strobe and ELT mounts; static ports
Details
 09-22-2007
4.00
ELT and strobe-pack mount
Details
 09-21-2007
4.50
Work floorboards, ELT mount
Details
 09-21-2007
0.30
Cockpit side console
Details
 09-20-2007
2.10
Fuselage stand; work floors, ELT mount, A/P mount
Details
 09-20-2007
1.10
Cockpit side console; axle-nut wrench tool
Details
 09-18-2007
1.90
Details
 09-17-2007
3.60
Cockpit side console; panel planning; ELT and A/P
Details
 09-16-2007
2.50
Details
 09-14-2007
3.40
Cockpit side console; cockpit paint tests
Details
 09-13-2007
0.70
Cockpit side console; interior paint test
Details
 09-08-2007
1.10
F-810A bulkhead modifications
Details
 08-10-2007
0.80
Right side console
Details
 07-11-2007
3.50
Right side console
Details
 07-06-2007
2.90
Right side console
Details
 07-05-2007
Side consoles; channel cap
Details
 07-04-2007
1.20
Right side console
Details
 07-03-2007
0.70
Right side console
Details
 07-02-2007
Right side console
Details
 06-27-2007
Left and right side consoles
Details
 06-26-2007
2.20
Details
 06-25-2007
2.10
Flap switch console
Details
 06-24-2007
1.70
Flap switch console
Details
 06-20-2007
0.50
Flap switch console prototyping
Details
 06-19-2007
2.20
Throttle quadrant
Details
 06-16-2007
1.70
Throttle quadrant, left side console & cover
Details
 06-14-2007
1.75
Throttle quadrant
Details
 06-13-2007
2.10
Cockpit side consoles
Details
 06-12-2007
2.40
Throttle quadrant
Details
 06-08-2007
1.75
Forward baggage floor
Details
 06-05-2007
1.60
Details
 06-04-2007
1.80
Details
 06-02-2007
0.70
Details
 05-31-2007
1.50
Details
 05-30-2007
0.50
Rudder pedals / brake master cylinders
Details
 05-26-2007
0.60
Flap motor installation
Details
 05-25-2007
4.00
Flap motor installation; under-floor planning
Details
 05-24-2007
0.50
Floorboard final trim and dimple
Details
 05-23-2007
3.50
Floorboards; seat hinges; aft cabin covers
Details
 05-22-2007
3.50
Floorboards; cabin side covers
Details
 05-21-2007
3.00
Flap actuator arm, floorboards, controls
Details
 05-16-2007
2.50
Floorboards
Details
 05-15-2007
2.20
Flight controls
Details
 05-11-2007
1.60
Rear control column hanger and spacers
Details
 05-10-2007
1.10
F-837 rear control hanger and spacers; floorboards
Details
 05-09-2007
3.00
Gear tower access covers, flap actuator
Details
 05-08-2007
1.90
Details
 05-05-2007
Floorboard platenuts and gear towers
Details
 05-04-2007
2.80
Details
 05-03-2007
3.00
Details
 05-02-2007
3.60
Gear tower covers
Details
 05-02-2007
0.00
Cool pneumatic tools; gear tower access holes
Details
 05-01-2007
4.50
Floorboards; gear tower access covers
Details
 04-29-2007
1.20
Floorboards and stuff
Details
 04-27-2007
2.30
Floorboards
Details
 04-26-2007
2.50
Floorboards
Details
 04-25-2007
3.40
Floorboards, foot wells
Details
 04-24-2007
4.50
Details
 04-20-2007
1.80
Floorboards
Details
 04-19-2007
Floor supports
Details
 01-17-2007
0.40
Grove landing gear
Details
 12-07-2006
QB Quality Control inspection
Details
 12-07-2006
0.40
Fuselage stand
Details
 11-29-2006
0.40
Fuselage stand
Details
 11-27-2006
0.70
Fuselage stand
Details
 11-26-2006
0.40
Fuselage stand
Details
