Rons Web Site
RV-7
Work Logs Found:
178
Category Work Time:
1066 Hours
Date
Hours
Work Log Summary
Details
01-06-2009
4.00
Cargo tie downs and painting
Details
12-22-2008
4.00
Wire management and general organization
Details
11-24-2008
5.00
Fuse assembly - 143 - Canopy Frame continued
Details
11-17-2008
3.00
Fuse assembly - 142 - Canopy Frame continued
Details
11-11-2008
Fuse assembly - 141 - Canopy Frame continued
Details
11-04-2008
8.00
Fuse assembly - 140 - Canopy Frame continued
Details
11-03-2008
6.00
Fuse assembly - 139 - Canopy Frame Riveting
Details
10-28-2008
10.00
Fuse assembly - 138 - Misc fuse work
Details
10-13-2008
6.00
Fuse assembly - 137 - Armrest Support Cont
Details
09-10-2008
4.00
Fuse assembly - 136 - Armrest reinforcement
Details
09-09-2008
5.00
Fuse assembly - 135 - Canopy lift strut work
Details
09-02-2008
5.00
Fuse assembly - 134 - Canopy frame cont
Details
09-02-2008
4.00
Fuse assembly - 133 - Canopy frame/coat rack
Details
08-26-2008
6.00
Fuse assembly - 132 - more Canopy frame work
Details
08-19-2008
6.00
Fuse assembly - 131 - Tipup Frame work
Details
08-12-2008
6.00
Fuse assembly - 130 - Gear mount refit
Details
08-04-2008
8.00
Fuse assembly - 129 - Removed Fuse gear mounts
Details
07-30-2008
8.00
Fuse assembly - 128 - Canopy Frame work cont
Details
07-08-2008
6.00
Fuse assembly - 127 - canopy frame fitup
Details
07-01-2008
10.00
Fuse assembly - 126 - Drilled Frame hinge points
Details
06-30-2008
6.00
Fuse assembly - 125 - Canopy Frame fitup
Details
06-24-2008
3.00
Fuse assembly - 124 - More Canopy work
Details
06-18-2008
4.00
Fuse assembly - 123 - Tipup frame prep work
Details
06-17-2008
6.00
Fuse assembly - 122 - Cabin Vents/Tipup prep
Details
06-16-2008
6.00
Fuse assembly - 121 - Rollbar wrap up and canopy l
Details
06-09-2008
5.00
Fuse assembly - 120 - Forward fuse riveting
Details
05-26-2008
Fuse assembly - 119 - Riveted the Forward rear ski
Details
05-25-2008
3.00
Fuse assembly - 118 - Preped forward rear skin for
Details
05-24-2008
3.00
Fuse assembly - 117 - Riveted Top Rear Skin
Details
04-22-2008
4.00
Fuse assembly - 116 - Cabin Frame/Rollbar construc
Details
04-21-2008
8.00
Fuse assembly - 115 - Cabin Frame/Rollbar construc
Details
04-20-2008
6.00
Fuse assembly - 114 - Cabin Frame/Rollbar construc
Details
04-13-2008
8.00
Fuse assembly - 113 - Cabin Frame/Rollbar construc
Details
03-31-2008
4.00
Fuse assembly - 110 - Installed the cabin heat lin
Details
03-26-2008
4.00
Fuse assembly - 108 - Tail wiring
Details
03-25-2008
8.00
Fuse assembly - 107 - Tail section cleanup
Details
03-24-2008
3.00
Fuse assembly - 106 - Installed Brake lines
Details
03-18-2008
5.00
Fuse assembly - 105 - Forward fuse assembly
Details
03-17-2008
4.00
Fuse assembly - 104 - Horz stab fairing
Details
03-12-2008
5.00
Fuse assembly - 103 - Rudder misc
Details
03-11-2008
6.00
Fuse assembly - 102 - Rudder Linkage/ELT
Details
03-10-2008
6.00
Fuse assembly - 101 - Vert stabilizer/emp fairing
Details
03-09-2008
6.00
Fuse assembly - 100 - Horz Stab installation
Details
03-05-2008
Fuse assembly - 99 - Rudder pedal installation
Details
03-03-2008
8.00
Fuse assembly - 98 - Cabin painting
Details
03-02-2008
5.00
Fuse assembly - 97 - Armrest wrapup
02-26-2008
10.00
Fuse assembly - 96 - Armrest Fabrication
Details
02-25-2008
6.00
Fuse assembly - 95 - Forward fuse/panel work
Details
02-19-2008
8.00
Fuse assembly - 94 - Canopy release linkage
Details
02-18-2008
6.00
Fuse assembly - 93 - Canopy opening mech
Details
02-17-2008
3.00
Fuse assembly - 92 - Forward fuse hatch work
Details
02-13-2008
3.00
Fuse assembly - 91 - Dress up work - rudder pedals
Details
02-12-2008
4.00
Fuse assembly - 90 - Fuse access hatches
Details
02-11-2008
3.00
Fuse assembly - 89 - Flap switch
Details
02-10-2008
8.00
Fuse assembly - 88 - Modular panel frame
Details
01-29-2008
8.00
Fuse assembly - 86 - Panel vent work
Details
01-28-2008
8.00
Fuse assembly - 85 - Forward upper fuse work
Details
01-22-2008
8.00
Fuse assembly - 84 - More forward fuse work.
Details
01-21-2008
8.00
Fuse assembly - 83 - Forward fuse access hatches
Details
01-07-2008
5.00
Fuse assembly - 82 - Forward fuse parts
Details
12-31-2007
4.00
Fuse assembly - 81 - started working on eyeball ve
Details
12-30-2007
5.00
Fuse assembly - 80 - side air vents
Details
12-19-2007
Fuse assembly - 79 - Rear aux power tap
Details
12-19-2007
4.00
Fuse assembly - 78 - Static Pitot line
Details
12-18-2007
5.00
Fuse assembly - 77 - Cargo area map pockets
Details
12-17-2007
5.00
Fuse assembly - 76 - Finished cargo bay attach lat
Details
12-11-2007
4.00
Fuse assembly - 75 - Baggage floor wrapup
Details
12-10-2007
5.00
Fuse assembly - 74 - seat pans/cargo floor
Details
12-04-2007
5.00
Fuse assembly - 73 - Seat back construction contin
Details
12-03-2007
8.00
Fuse assembly - 72 - Seat back construction contin
Details
12-02-2007
8.00
Fuse assembly - 71 - Seat back construction
Details
11-30-2007
Fuse assembly - 70 - ELT Wire pulled
Details
11-30-2007
5.00
Fuse assembly - 69 - Flap wiring work
Details
11-28-2007
5.00
Fuse assembly - 68 - Cargo bay hatches
Details
11-27-2007
Fuse assembly - 67 - nutplates and misc
Details
11-21-2007
4.00
Fuse assembly - 66 - Upper rear panel work
Details
11-20-2007
5.00
Fuse assembly - 65 - Interior panel
Details
11-19-2007
5.00
Fuse assembly - 64 - More flap work and covers
Details
11-12-2007
5.00
Fuse assembly - 63 - Flap system
Details
11-07-2007
8.00
Fuse assembly - 62 - Flap work
Details
11-04-2007
20.00
Fuse assembly - 61 - Fuel selector valve redo
Details
10-30-2007
5.00
Fuse assembly - 60 - Flap work
Details
10-29-2007
5.00
Fuse assembly - 59 - Remounting of Gascolator
Details
10-28-2007
Fuse assembly - 58 - engine mount
Details
10-24-2007
5.00
Fuse assembly - 57 - Pitch servo and flap motor wi
Details
10-23-2007
4.00
Fuse assembly - 56 - Installed the firewall recess
Details
10-22-2007
9.00
Fuse assembly - 55 - Fuel system and Cabin heat
Details
10-15-2007
12.00
Fuse assembly - 54 - Brake/Rudder pedals
Details
10-10-2007
6.00
Fuse assembly - 53 - Fuel system continued
Details
10-09-2007
10.00
Fuse assembly - 52 - Fuel system stuff
Details
10-08-2007
10.00
Fuse assembly - 51 - Step Installation
Details
09-26-2007
5.00
Fuse assembly - 50 - Fuse conduit
Details
09-25-2007
7.00
Fuse assembly - 49 - Aileron Trim system
Details
09-24-2007
8.00
Fuse assembly - 48 - Forward fuse sheet metal work
Details
09-18-2007
6.00
Fuse assembly - 47 - Steps/FI Pump kit
Details
09-17-2007
5.00
Fuse assembly - 46 - Brake lines/Rudder Cables
Details
09-12-2007
8.00
Fuse assembly - 45 - Right Fuel line vent and Left
Details
09-11-2007
5.00
Fuse assembly - 44 - Left Fuel Vent line
Details
09-10-2007
6.00
Fuse assembly - 43 - Gascolator/Vents/Brake fittin
Details
09-03-2007
7.00
Fuse assembly - 42 - Selector valve/fuel lines/gas
Details
09-02-2007
8.00
Fuse assembly - 41 - Canopy Latch/Fuel System
Details
09-01-2007
8.00
Fuse assembly - 40 - Canopy Latch/Fuel valve
Details
08-31-2007
5.00
Fuse assembly - 39 - Canopy latch
Details
08-21-2007
10.00
Fuse assembly - 38 - Strobe pwr/Brake pedals/canop
Details
08-19-2007
4.00
Fuse assembly - 37 - Vent/Brake fitting
Details
08-15-2007
5.00
Fuse assembly - 36 - Strut march drilling and misc
Details
08-14-2007
5.00
Fuse assembly - 35 - Control Column and forward el
Details
08-13-2007
8.00
Fuse assembly - 34 - Misc riveting wrapup in fuse
Details
08-08-2007
4.00
Fuse assembly - 33 - Brake reservoir/rudder bracke
Details
08-06-2007
8.50
Fuse assembly - 32 - Gear attach and other misc
Details
08-01-2007
6.00
Fuse assembly - 31 - Gear attach
Details
07-31-2007
Tech visit
Details
07-30-2007
9.00
Fuse assembly - 31 - Side skin riveting
Details
07-24-2007
5.00
Fuse assembly - 30 - Emp attach fittings
Details
07-23-2007
5.00
Fuse assembly - 29 - Upper stringers and Longeron
Details
07-18-2007
4.00
Fuse assembly - 28 - Emp attach fittings
Details
07-17-2007
Fuse assembly - 27 - Riveting continued
Details
07-16-2007
7.00
Fuse assembly - 26 - Rudder pedals/fuse riveting
Details
07-15-2007
Fuse assembly - 25 - Brakes/rudder pedals
Details
07-10-2007
6.00
Fuse assembly - 24 - Misc prep work
Details
07-09-2007
7.00
Fuse assembly - 23 - forward structural
Details
07-08-2007
10.00
Fuse assembly - 22 - forward structural
Details
07-07-2007
8.00
Fuse assembly - 21 - forward structural
Details
07-06-2007
7.00
Fuse assembly - 20 - forward structural
Details
06-26-2007
8.00
Fuse assembly - 19 - forward fuse structural
Details
06-25-2007
6.00
Fuse assembly - 18 - Brackets, engine mount, left
Details
06-24-2007
1.50
Fuse assembly - 17 - Prime forward structural
Details
06-20-2007
6.00
Fuse assembly - 16 - forward fuse structural
Details
06-19-2007
8.00
Fuse assembly - 15 - forward fuse structural
Details
06-18-2007
6.00
Fuse assembly - 14 - forward fuse structural
Details
06-17-2007
5.00
Fuse assembly - 13 - forward fuse structural
Details
06-10-2007
5.00
Fuse assembly - 12 - Firewall Dimpling
Details
06-06-2007
7.00
Fuse assembly - 11 - Firewall Drilling
Details
06-04-2007
Fuse assembly - 10 - Firewall installation - Fitup
Details
05-28-2007
7.00
Fuse assembly - 9 - Countersinking Longerons
Details
05-27-2007
4.00
Fuse assembly - 8 - Drilling longerorns
Details
05-23-2007
7.00
Fuse assembly - 7
Details
05-22-2007
8.00
Fuse assembly - 6
Details
05-21-2007
5.00
Fuse assembly - 5
Details
05-15-2007
7.00
Fuse assembly - 4
Details
05-14-2007
8.00
Fuse assembly - 3 - bad day
Details
05-09-2007
6.00
Fuse assembly - 2
Details
05-08-2007
8.00
Fuse assembly - 1
Details
05-07-2007
8.00
Center Section - 10
Details
05-06-2007
3.00
Center Section - 9
Details
05-01-2007
7.00
Center Section - 8
Details
04-29-2007
4.00
Center Section - 7
Details
04-25-2007
8.00
Center Section - 6
Details
04-24-2007
4.00
Center Section - 5
Details
04-23-2007
9.00
Center Section - 4
Details
04-21-2007
7.00
Center Section - 3
Details
04-17-2007
6.00
Center Section - 2
Details
04-15-2007
4.00
Center Section - 1
Details
04-10-2007
7.00
Tail cone cont - 6 - wrap up
Details
04-09-2007
7.00
Tail cone cont - 5
Details
04-02-2007
8.00
Tail cone cont - 4
Details
03-28-2007
8.00
Tail cone cont - 3
Details
03-27-2007
8.00
Tail Cone cont - 2
Details
03-26-2007
10.00
Tail Cone Cont - 1
Details
03-25-2007
8.00
Tail cone work
Details
03-20-2007
12.00
Tailcone work - 7/7A conversion
Details
02-28-2007
8.00
Longeron day!!!!
Details
02-27-2007
8.00
Finished bulkhead assembly
Details
02-25-2007
8.00
Bulkhead 706 assembly/AP Servo
Details
02-20-2007
8.00
Bulkhead 706 and pitch servo prework
Details
02-19-2007
8.00
Finishing Bulkhead 705
Details
02-14-2007
8.00
Bulkhead 705 continued
Details
02-13-2007
4.00
705 Bulkhead work
Details
02-11-2007
8.00
Finished Firewall assembly
Details
02-10-2007
5.00
Firewall prep work cont.
Details
02-06-2007
8.00
Firewall Prep
Details
02-05-2007
6.00
Center Section Prep
Details
01-29-2007
8.00
Control Column setup
Details
01-28-2007
8.00
Started working on the Fuse kit! Former 704
Details
01-27-2007
7.00
Unpacked and inventoried the Fuselage kit
Details
01-25-2007
1.50
Fuselage Kit Arrived!!!
Details
12-13-2006
0.10
Fuse kit to ship 1/15/06!
Details
11-20-2006
Fuselage Kit ordered!!!!
Details
RV-7 Home
1793
Fuel Tanks
1066
Lighting
326
