Martin's Web Site
Work Logs Found: 166
Category Work Time: 634 Hours
 Date
Hours
Work Log Summary
Details
 04-30-2018
3.00
Fuel Line and Wiring Harness routing
Details
 01-27-2018
Repaired damaged baggage compartment stringer
Details
 12-31-2017
3.00
Wing tie-down storage mounts
Details
 11-26-2016
Rivet aft upper skin to bulkheads and longerons
Details
 07-31-2016
10.00
Canopy bow fiberglass molding
Details
 11-01-2008
5.00
Riveted foreward subpanel assembly
Details
 11-10-2007
Miscellaneous Riveting
Details
 11-07-2007
Tail section access plates
Details
 10-17-2007
3.00
Finished painting cabin parts
Details
 10-15-2007
10.00
Riveted seatbacks; painted cabin
Details
 10-15-2007
5.00
Cabin area priming
Details
 10-13-2007
12.00
Prep Fuselage for priming
Details
 10-08-2007
7.00
Finished instrument panel mounting
Details
 10-06-2007
5.00
Forward Top skin
Details
 10-04-2007
1.50
Subpanel Work
Details
 09-29-2007
10.50
F768 Subpanel assembly
Details
 09-25-2007
2.50
Finished 703B angle
Details
 09-19-2007
1.50
Forward Cabin work
Details
 09-18-2007
Foreward cabin work
Details
 09-08-2007
12.00
Fixed Problem with Cabin Frame
Details
 09-03-2007
6.00
Finished Emp Fitting; worked Cabin Frame
Details
 09-02-2007
4.50
Empennage Fitting
Details
 09-01-2007
8.00
Empennage Fitting
Details
 08-31-2007
3.50
Drill Elevator Horns; unpack Finish Kit
Details
 08-25-2007
6.00
Aft-End Upper Fuselage prep work
Details
 08-24-2007
6.00
Made F790 elevator pushrod
Details
 08-23-2007
9.00
Cabin Frame Construction Completed
Details
 08-22-2007
6.00
Details
 08-21-2007
4.00
Details
 08-19-2007
4.00
Details
 08-18-2007
3.00
Wing Removal
Details
 08-14-2007
1.50
Misc Wing-mate cleanup tasks
Details
 08-11-2007
6.00
Fuel line installation
Details
 08-09-2007
9.00
Fuel Line installation
Details
 08-07-2007
4.00
Finished rigging ailerons and flaps
Details
 08-05-2007
3.00
Cut holes in fuselage for flap pushrods
 07-29-2007
3.50
Rigged ailerons
Details
 07-28-2007
4.00
Fuel Tank Attach Bracket
Details
 07-27-2007
1.50
Drilled Rear Spar Attach point
Details
 07-24-2007
2.50
Measured Wing Sweep and Incidence
Details
 07-21-2007
4.00
Wings Mated!
Details
 07-19-2007
Finished prep for wing mate
Details
 07-17-2007
Wing Mate Prep Work
Details
 07-16-2007
Wing Mate Prep Work
Details
 07-08-2007
10.00
Install Ldg Gear Mounts
Details
 07-05-2007
Fit Ldg Gear Legs to Mounts
Details
 07-04-2007
4.00
Completed Electric Flap Install
Details
 07-02-2007
Electric Flaps
Details
 07-01-2007
2.50
Electric Flaps
Details
 06-30-2007
2.50
Electric Flaps
Details
 06-28-2007
5.00
Completed Forward Covers
Details
 06-27-2007
Began Forward Cabin Covers
Details
 06-26-2007
Finished drilling seatbacks
Details
 06-25-2007
2.50
Seat Back Assembly
Details
 06-24-2007
7.00
Fabricated Seat Back pieces
Details
 06-23-2007
7.00
Floors and Control Rod Tunnel
Details
 06-21-2007
4.00
Finished Aft Seat Skins, F715 nutplates
Details
 06-19-2007
Seat Hinge Work
Details
 06-18-2007
3.00
Fwd Baggage covers and seat hinges
Details
 06-16-2007
3.50
Baggage bulkhead and tunnel cover
Details
 06-14-2007
F706 nutplates
Details
 06-13-2007
F706 Nutplates
Details
 06-12-2007
Baggage Bulkhead Fabrication
Details
 06-11-2007
Baggage floor complete; started bulkhead
Details
 06-10-2007
4.00
Baggage area installation
Details
 06-06-2007
3.00
Attached steps to fuselage
Details
 06-05-2007
Fit and drill F774 Forward Top Skin
Details
 06-04-2007
1.50
Clecoed and drilled F775 Aft Top Skin
 05-30-2007
4.00
Finished riveting, started Aft Top Skin
Details
 05-29-2007
2.50
Riveted gussets, canopy deck pieces
 05-28-2007
2.50
Primed miscellaneous parts
Details
 05-27-2007
9.00
Side Rails & Canopy Decks, & Misc
Details
 05-26-2007
9.00
F714 Aft Deck & miscellaneous
Details
 05-25-2007
4.00
Bellcrank Support
Details
 05-19-2007
Flipped the Canoe!
Details
 05-12-2007
4.00
Foreward bottom skin riveting
Details
 05-05-2007
4.50
Foreward Fuselage Riveting
Details
 05-01-2007
Details
 04-29-2007
6.00
Fuselage rivet squeezing
Details
 04-21-2007
Fwd Fuselage Riveting
Details
 04-20-2007
2.50
Fuselage Reassembly
Details
 04-17-2007
1.50
Aft-Mid Fuselage prep for reassembly
Details
 04-16-2007
Mid-Fuselage Riveting
Details
 04-15-2007
4.00
Fuselage skin priming
Details
 04-14-2007
6.50
Fuselage parts cleaning and priming
Details
 04-13-2007
Aft/Mid Fuselage dimpling
Details
 04-11-2007
3.00
Longeron and aft fuselage prep
Details
 04-09-2007
Longeron Prep
Details
 04-08-2007
4.00
Fuselage prep for priming
Details
 03-25-2007
4.00
Foreward fuselage prep - side skins
Details
 03-23-2007
Foreward fuselage prep, 7101-L replace
Details
 03-19-2007
1.50
Details
 03-18-2007
6.00
More prep work
Details
 03-12-2007
F772 Bottom Skin Prep
Details
 03-10-2007
6.00
WD-657 Step and Fuselage Disassembly
Details
 03-09-2007
6.00
WD-657 External Step
Details
 01-15-2007
2.50
Framed Baggage Area
Details
 01-07-2007
4.50
Floor stiffener install
Details
 01-04-2007
2.50
F6118 Rudder pedal brace
Details
 01-03-2007
3.50
Drilled mounting holes for rudder assy's
Details
 01-01-2007
7.00
Brake/rudder pedal assembly
Details
 12-30-2006
3.50
Assembled brake pedals
Details
 12-29-2006
5.00
Fab & Install F796B angles
 12-28-2006
Fab'd all 4 F796C&D Spacers
 12-27-2006
2.50
Forward bulkhead fitting
Details
 12-26-2006
7.00
Lower Longeron and F-684 Gusset install
Details
 12-23-2006
4.50
Installed Aux Longerons & Fwd Stiffners
Details
 12-20-2006
1.50
Aux Longerons work
Details
 12-16-2006
Cut holes for landing gear
Details
 12-14-2006
1.50
Drilled F770 side skins to firewall
Details
 12-11-2006
1.50
Firewall mounting
Details
 11-25-2006
5.00
Joining Rear and Center Fuselage Assy.
Details
 11-24-2006
Details
 11-23-2006
4.00
Center Fuselage Joining
Details
 11-22-2006
3.00
Details
 11-20-2006
Details
 11-19-2006
Center Fuselage Assembly
Details
 11-18-2006
1.50
Finished riveting aft fuselage
Details
 11-15-2006
Mid-Fuselage Assembly
Details
 11-11-2006
3.00
Mid-Fuselage riveting
Details
 11-10-2006
9.00
Mid Fuselage Riveting
Details
 11-09-2006
7.00
Mid Fuselage Prime
Details
 11-08-2006
1.50
Finished Dimpling Mid fuselage
Details
 11-04-2006
8.00
Mid Fuselage Prep
Details
 11-03-2006
F704 Fit and drill
Details
 10-09-2006
4.00
F716 work
Details
 10-08-2006
1.50
F716 work
Details
 10-07-2006
3.00
Fab'd misc. parts
Details
 10-02-2006
1.50
Began Riveting Aft Bottom Skin
Details
 10-01-2006
3.00
Aft fuselage reassembly & riveting
Details
 09-30-2006
10.00
Finish Aft Fuselage Prep
Details
 09-27-2006
Aft Fuselage Prep for Riveting
Details
 09-25-2006
Aft Fuselage Prep for riveting
Details
 09-24-2006
Aft Fuselage Disassembly for prep
 09-23-2006
7.00
Aft fuselage assembly (continued)
Details
 09-22-2006
4.50
Aft fuselage assembly (cont)
Details
 09-20-2006
Began Aft Fuselage Assembly
Details
 09-17-2006
5.00
Finished longerons and J-chanl stringers
Details
 09-16-2006
12.00
Longeron Bending
Details
 09-10-2006
Longeron prep
Details
 09-04-2006
4.00
Aft Fuselage Bulkhead Assembly
Details
 09-03-2006
Primed Aft bulkhead pieces
Details
 09-02-2006
8.00
F711&F712 Fabrication
Details
 08-29-2006
4.00
F706 Fabrication
Details
 08-27-2006
6.00
Bulkhead prep & 706 Bulkhead Fabrication
Details
 08-19-2006
4.50
Assembled F705 Bulkhead
Details
 08-18-2006
Primed F705 Bulkhead Parts
Details
 08-17-2006
2.50
Prepped F705 Bulkhead parts for priming
 03-30-2006
1.50
F705 Bulkhead work
Details
 03-26-2006
F705 Bulkhead Work
Details
 03-21-2006
6.00
F705 Bulkhead work
Details
 03-19-2006
3.50
F704 Bulkhead Work
Details
 03-18-2006
3.00
Rivet F704 Bulkhead
Details
 03-11-2006
7.00
F704 Bulkhead work
Details
 03-05-2006
6.50
F704 Bulkhead work
Details
 03-04-2006
704 Bulkhead Work
Details
 02-28-2006
1.50
F704 Bulkhead drilling
Details
 10-23-2005
Finished firewall riveting.
 10-15-2005
4.00
Wing skin riveting and firewall riveting
Details
 10-14-2005
1.50
Firewall work
Details
 10-10-2005
3.00
Firewall work
Details
 10-08-2005
3.00
Firewall work
Details
 10-01-2005
2.50
Firewall Assembly
Details
 09-30-2005
1.50
Begin Firewall assembly
Details
 09-26-2005
Completed Fuselage Inventory
 09-25-2005
2.50
Began Inventory of Fuselage Kit
