Martin's Web Site
RV-7A
Work Logs Found:
124
Category Work Time:
412 Hours
Date
Hours
Work Log Summary
Details
03-24-2018
8.00
Remove Right Fuel Tank
Details
12-26-2017
7.00
Wired Pitot Probe
Details
07-03-2016
6.00
Fuel pickup safety service bulletin
Details
06-26-2016
20.00
Complete Right Wing Tip
Details
05-09-2016
3.00
Completed Right Wing Tip attach points
Details
04-25-2016
Installed tip rib
Details
04-24-2016
Match-drilled right wing tip to wing
Details
04-23-2016
6.00
Right wing light kit complete
Details
04-20-2016
3.00
Right Wing Light Cut out
Details
04-16-2016
3.00
finish cleanup of left wing
Details
04-05-2016
Install foam rib in left wingtip
Details
03-20-2016
8.00
Left Wing tip fairing; SB06-2-23
Details
03-06-2016
5.00
Left wingtip epoxy and tip lens install
Details
03-02-2016
Finished installing nutplates on left tip
02-28-2016
6.00
Match-drill left wing tip
Details
02-13-2016
4.00
Completed Left Wing Landing Light Kit
11-12-2005
2.50
Finish wing riveting, etc
Details
11-07-2005
Finished Riveting Wing Skins
Details
11-03-2005
2.50
Wing Skin Riveting
Details
10-17-2005
Skin Work
Details
10-06-2005
2.50
Rivet on Left Bottom Inboard Skin
Details
09-21-2005
0.50
Finished Dimpling Left Bottom Wing Skins
09-20-2005
8.00
Left Wing Bottom skin prep
Details
09-19-2005
5.00
Mount Left Aileron, flap hinge work
Details
09-17-2005
6.00
Finish Prep of Bottom Right Wing Skins
Details
09-15-2005
1.50
Prepping Right Bottom Wing Skins
Details
09-13-2005
2.50
Prepped Right Bottom Wing Skins
Details
09-12-2005
4.00
Various Right Wing Tasks
Details
09-05-2005
5.00
Leak Testing and Right Aileron Mounting
Details
09-04-2005
4.00
Leak Test Fuel Tanks
Details
09-02-2005
3.00
Finish right wing aileron attach. , etc
Details
09-01-2005
Prime inside of aileron pushrods
Details
08-28-2005
3.00
Aileron/Flap Attach Work (Both Wings)
Details
08-27-2005
3.50
Aileron/Flap Attachment Work (Left Wing)
Details
08-26-2005
Deburring and Aileron Bracket Riveting
Details
08-21-2005
1.50
Prepared Aileron Brackets
Details
08-20-2005
8.50
Completed Flaps
Details
08-19-2005
3.50
Flap work
Details
08-18-2005
1.50
Dimpled Flap parts
Details
08-17-2005
Flap Drilling and Deburring
Details
08-16-2005
Primed Stiffener plates
Details
08-15-2005
3.00
Flap stiffener fab
Details
08-14-2005
5.50
Flap assembly and match drilling
Details
08-13-2005
6.00
Completed Ailerons
Details
08-12-2005
5.00
Aileron Riveting
Details
08-08-2005
3.00
Finished sealing left tank....maybe
Details
08-07-2005
3.00
Finished Sealing Right Tank!
Details
08-06-2005
4.00
Fuel Tank Prep for final sealing
Details
08-04-2005
Aileron Prep
Details
08-03-2005
Debur ailerons
Details
08-02-2005
Match Drilled Ailerons
Details
08-01-2005
2.50
Tank & Aileron Work
Details
07-31-2005
5.00
Sealed Inner/Outer Ribs
Details
07-30-2005
Fuel Tank Component Work
Details
07-29-2005
1.50
Fuel Tank Work
Details
07-28-2005
Fuel Tank Sealing (Pt3)
Details
07-27-2005
4.00
Fuel Tank Sealing, Pt 2
Details
07-25-2005
2.50
Aileron Work
Details
07-24-2005
4.00
Aileron Stiffeners Installed
Details
07-23-2005
Aileron Stiffener prep
Details
07-21-2005
4.00
Sealing Fuel Tanks, Part 1
Details
07-20-2005
3.00
Fuel Tank Prep & Cleaning
Details
07-18-2005
Fuel Tank Prep
Details
07-17-2005
Fuel Tank Sealing Prep
Details
07-16-2005
4.00
Fuel Tank Prep
Details
07-15-2005
3.00
Right Fuel Tank Prep
Details
07-12-2005
Riveted Right Wing Top Skins
Details
07-10-2005
1.50
Rt Tank Fuel Level Sensor Work
Details
07-09-2005
4.50
Rt Tank Inboard Rib Prep
Details
07-08-2005
Rt Tank Rib Stiffeners
Details
07-07-2005
Right Fuel Tank and Wing Work
Details
07-06-2005
1.50
Finish Rt Wing prep for riveting
Details
07-05-2005
Dimple Right Wing
Details
07-04-2005
3.50
Right Wing Deburr/Dimple
Details
07-03-2005
8.00
Right Leading Edge Finish, Spar Work
Details
07-02-2005
5.50
Prep Right Leading Edge for Riveting
Details
06-30-2005
4.00
Details
06-28-2005
2.50
Prepare Rt Fuel Tank Z-brackets
Details
06-27-2005
2.50
Right Wing and Fuel Tank Work
Details
06-26-2005
4.50
Right Wing / Leading Edge Work
Details
06-25-2005
4.50
Rivet L Top W Skins, Put R Wing on Stand
Details
06-24-2005
0.50
Deburr Wing Skin
Details
06-23-2005
1.50
Prepare Pitot Mast
Details
06-22-2005
3.50
Rivet Left Leading Edge
Details
06-20-2005
3.50
Left Wing Top Skin Prep and Mount
Details
06-19-2005
4.00
Left Wing Upper Skins prep
Details
06-18-2005
Prep rear spar to skin holes
Details
06-16-2005
Left Wing Skeleton Deburr/Dimple
Details
06-15-2005
CS Front spar for skin dimples
Details
06-14-2005
2.50
Left Leading Edge Finished, etc
Details
06-13-2005
Left Leading Edge Riveting
Details
06-12-2005
4.00
Left Leading Edge Prep for Riveting
Details
06-10-2005
4.00
Left Fuel Tank Prep
Details
06-09-2005
Deburr left wing upper skins
Details
06-08-2005
1.50
Cut T711 stiffeners
Details
06-06-2005
3.50
Left Fuel Tank Prep continued
Details
06-05-2005
2.50
Fuel Tank skin prep
Details
06-04-2005
6.00
Left Fuel Tank Fitting
Details
06-03-2005
5.50
Left fuel tank attach Z-brackets
Details
05-30-2005
3.00
Leading Edge Assy (left wing, pt 2)
Details
05-27-2005
4.00
Leading Edge Assembly (left wing)
Details
05-25-2005
Finish Match Drilling Left Wing Skins
Details
05-24-2005
2.50
Match Drilled Left Wing Top Skins
Details
04-17-2005
4.00
Primed Ribs
Details
04-16-2005
4.00
Prepped Ribs for priming
Details
04-06-2005
Corrected Left Spar Manufacturing Flaw
Details
04-05-2005
Deburred Wing Ribs
Details
04-04-2005
Debur Ribs
Details
04-03-2005
2.50
Conduit Holes
Details
03-30-2005
3.00
Drilled Wing Skeletons
Details
03-28-2005
Clecoed Right Wing Skeleton
Details
03-14-2005
3.00
Complete Front/Rear Spar assembly
Details
03-12-2005
10.00
Rear Spar Assembly/Priming
Details
03-11-2005
Rear Spar Assembly
Details
03-10-2005
3.00
Prep rear spar pieces
Details
03-06-2005
2.50
Assembled Wing Tiedowns
Details
03-05-2005
4.00
Fabricated Wing TieDowns
Details
03-02-2005
More spar nutplates
Details
03-02-2005
2.50
Front Spar Prep
Details
02-28-2005
1.50
CS tank attach screw holes
Details
02-27-2005
5.00
Tank skin platenuts
Details
02-22-2005
Inventory Completed
Details
02-19-2005
2.50
Inventory Continued
Details
02-18-2005
1.50
Began Inventory
Details
RV-7A Home
1863
Cowl/Spinner/Baffles
208
634
Hardware
Systems
412
