Martin's Web Site
RV-7A
Work Logs Found:
74
Category Work Time:
208 Hours
Date
Hours
Work Log Summary
Details
12-27-2015
4.00
Hung Rudder and Elevators
Details
12-23-2015
4.00
Primed Elevators and Rudder
Details
12-21-2015
Painting Prep
Details
12-20-2015
Final Sanding of Rudder and Elevators
Details
12-19-2015
4.00
Epoxy Top Coat
Details
12-18-2015
4.00
Sanding and Filling!
Details
12-17-2015
Applied Filler to Elevators and Rudder
Details
12-16-2015
Rudder, Elevator Sanding
Details
12-10-2015
HS Tip sanding
Details
12-09-2015
Sanding the HS Tips
Details
02-05-2005
4.00
Finished Elevators
Details
01-29-2005
6.00
Elevator Finishing
Details
01-22-2005
7.00
Completed Trim Tab (1 exception!)
Details
01-20-2005
Trim Tab Prep
Details
01-19-2005
1.50
Trim tab prep
Details
01-18-2005
2.50
Rivet L Elevator skin
Details
01-17-2005
5.00
L. Elevator prep and riveting
Details
01-16-2005
8.00
Close elevator at trim tab cutout
Details
01-15-2005
Prep Elevator Trim parts
Details
01-02-2005
3.50
Right Elevator riveting
Details
01-01-2005
3.00
Elevator priming and riveting
Details
12-25-2004
Left elevator prep
Details
12-24-2004
1.50
Left Elevator prep
Details
12-23-2004
Dimple Right Elevator
Details
12-22-2004
3.00
Right Elevator assembly prep
Details
12-20-2004
Elevator Skins drilled
Details
12-19-2004
1.50
Elevator Skeleton work
Details
12-16-2004
2.50
Elevator skeleton prep
Details
12-13-2004
Back Rivet Elevator Skins
Details
12-12-2004
Rudder Complete
Details
12-12-2004
1.50
Dimple Elevator Skins/Stiffeners
Details
12-11-2004
4.50
Rudder Riveting
Details
12-08-2004
1.50
Elevator Stiffeners
Details
12-07-2004
Elevator Stiffeners
Details
12-06-2004
Cut Elevator Stiffeners
Details
12-05-2004
4.50
Rudder Riveting
Details
12-05-2004
1.50
Rivet Rudder Skeleton
Details
12-04-2004
4.50
Rudder Riveting
Details
12-01-2004
Rudder Work
Details
11-29-2004
2.50
Rudder Prep
Details
11-27-2004
3.00
Rudder assembly and deburr
Details
11-26-2004
3.50
Assemble rudder skeleton
Details
11-25-2004
5.00
Finish rudder stiffener/skin work
Details
11-24-2004
3.00
Dimple Rudder Skins
Details
11-20-2004
1.50
Drill Rudder Stiffeners
Details
11-19-2004
Trimmed Rudder Stiffeners
11-17-2004
3.50
Completed VS
Details
11-16-2004
3.00
Rivet VS skeleton
Details
11-14-2004
Primed VS parts
Details
11-13-2004
5.00
VS prep work
Details
11-11-2004
3.50
dimple, CS VS parts
Details
11-09-2004
3.00
Drilled and Deburred VS parts
Details
11-08-2004
1.50
Drilled VS skeleton
Details
11-07-2004
Cleco'd rear VS, prepped ribs
11-06-2004
6.00
Finished HS
Details
11-05-2004
3.00
Finish riveting left HS
Details
11-04-2004
Rivet HS707 left to skin
Details
11-03-2004
Riveted the HS-707s (top)
Details
11-02-2004
HS riveting
Details
11-01-2004
Rivet HS Rear Spar
Details
10-31-2004
2.50
Primed HS parts
Details
10-30-2004
Cleaned/Etched HS parts
Details
10-29-2004
2.50
Dimpled HS skins, edge finishing
Details
10-28-2004
2.50
HS Dimpling
Details
10-26-2004
2.50
Deburr HS parts
Details
10-24-2004
3.50
Drilled HS, Right Side
Details
10-23-2004
5.00
Drill HS, Left side
Details
10-22-2004
2.50
Finish HS ribs prep
Details
10-20-2004
Trim HS404 Flanges
Details
10-19-2004
5.50
Front Spar Assembly
Details
10-18-2004
1.50
Asmble HS-411; Fin HS R Spar Prep
Details
10-17-2004
2.50
Match drilled HS rear spar
Details
10-16-2004
4.00
Prep HS Rear Spar Stiffeners
10-15-2004
3.00
Inventory Empannage Kit
RV-7A Home
1863
Cowl/Spinner/Baffles
208
634
Hardware
Systems
412
