ROBERT'S WEB SITE
Work
Logs
Found:
125
Category Work Time: 568 Hours
Date
Hours
Work Log Summary
Details
11-02-2018
Second and third flight
Details
11-01-2018
8.00
Strut covering, drain holes
Details
10-31-2018
3.50
WIng Twist
Details
10-27-2018
First Flight!
Details
10-26-2018
Airworthiness Inspection
Details
10-25-2018
5.00
Getting ready for inspection
Details
10-23-2018
Tail cover panel
Details
10-18-2018
3.00
Safety Prop
Details
10-17-2018
4.00
Taxi 2, interior
Details
10-16-2018
5.00
First Taxi
Details
10-15-2018
5.00
Shim
Details
10-11-2018
6.00
Start and run, turtledeck
Details
10-10-2018
6.00
First start attempt
Details
10-09-2018
5.00
LE Closeouts, turtledeck closeouts
Details
10-05-2018
8.00
Fuel test
Details
10-04-2018
6.00
Final control rigging, flaperons
Details
10-03-2018
6.00
Turtle Deck, brakes
Details
09-29-2018
6.00
Cowling, Weighing
Details
09-28-2018
8.00
Flaperons, Turtledeck, brakes
Details
09-27-2018
4.00
Flaperon hinges, scales
Details
09-26-2018
6.50
Wire Clean up, Seats, Bag Compartment
Details
09-25-2018
7.00
Wiring
Details
09-24-2018
4.00
Wingtip, wiring
Details
09-21-2018
4.50
Wing wiring, Fuel Placard
Details
09-20-2018
6.00
Wings are on
Details
09-19-2018
6.00
Struts, tail
Details
09-15-2018
4.50
Strut Superfil, rudder install, Nav/strobe
Details
09-12-2018
6.50
Strut fairings
Details
09-05-2018
5.00
Painting wingtips and stripes
Details
09-04-2018
6.00
Moving to hangar
Details
09-03-2018
5.00
Tail Access Covers
Details
09-02-2018
4.00
Glare shield
Details
08-27-2018
5.00
Wire bundle tying
Details
08-22-2018
5.00
Interior Covering
Details
08-21-2018
6.00
Stickers
Details
08-20-2018
5.00
EFIS fix, glare shield
Details
08-19-2018
3.00
Wiring, EFIS programming
Details
08-18-2018
5.00
EFIS Power Up
Details
08-17-2018
8.00
Wiring Harnesses
Details
08-16-2018
8.00
Electrical, VHF antenna
Details
08-15-2018
4.00
Details
08-14-2018
4.00
Window bolts electrical
Details
08-13-2018
6.00
Prop hub, Fuel Pressure, wiring
Details
08-12-2018
5.00
Details
08-10-2018
5.00
Details
08-09-2018
4.00
Windshield trimming
Details
08-08-2018
4.50
Blue Cowl and rudder paint
Details
08-07-2018
8.00
Painting the cowlings
Details
08-06-2018
8.00
WIndshield
Details
08-05-2018
5.00
Butt ribs, wiring.
Details
08-04-2018
Sanding cowling
Details
08-03-2018
6.00
Fiberglass
Details
07-30-2018
5.00
Finished cowling
Details
07-25-2018
5.00
Camlocks
Details
07-20-2018
5.00
Panel labeling
Details
07-19-2018
5.00
Painting Panel
Details
07-15-2018
4.00
Sanding cowling
Details
07-13-2018
5.00
Cowling work
Details
07-06-2018
5.00
Cowling cutting
Details
07-05-2018
4.00
Cowling
Details
07-04-2018
5.00
Prop Slipring, cowling
Details
06-14-2018
Panel Stuff
Details
06-12-2018
3.00
Wiring
Details
06-06-2018
4.00
Fuse Box, panel planning
Details
06-05-2018
5.00
Instrument panel hinges
Details
06-04-2018
5.00
ECU Install
Details
05-30-2018
4.00
Fuel line finishing
Details
05-29-2018
4.00
Fuel tubing
Details
05-28-2018
4.00
Fuel lines and hoses
Details
05-23-2018
5.00
Fuel lines, electrical
Details
05-22-2018
6.00
Water and Oil Hoses
Details
05-21-2018
5.00
Oil cooler
Details
05-20-2018
4.00
Radiator
Details
05-16-2018
5.00
Fitting Cowling
Details
05-15-2018
5.00
Cowling
Details
05-14-2018
Avionics tray
Details
05-09-2018
2.50
Engine Fuse Box, Fuel pump
Details
05-08-2018
6.00
Boot cowl, heater
Details
05-07-2018
3.00
Brake lines, heater
Details
05-06-2018
5.00
Brake Lines, Tail Beacon
Details
05-05-2018
4.00
Brakes
Details
04-28-2018
3.00
Cut panel, Oil tank
Details
04-27-2018
5.00
Brrakes Engine Install
Details
04-26-2018
4.00
Boot Cowl, Firewall, Engine Unpack
Details
04-22-2018
Landing Gear and Firewall Forward
Details
02-03-2018
Second Coat of Varnish
Details
02-01-2018
5.00
Torque, pitot tube mast
Details
01-31-2018
4.00
Tail wire, torque
Details
01-26-2018
4.00
Doors again
Details
01-25-2018
5.00
Doors
Details
01-24-2018
4.00
Flight control rigging
Details
01-18-2018
5.00
Super Fil and Sanding
Details
01-17-2018
5.00
Empenage Tips, sanding
Details
01-16-2018
Rudder stops, super fill
Details
01-12-2018
4.00
Door frame, rudder stops
Details
01-11-2018
4.50
Hysol Door and Tail access
Details
01-10-2018
6.00
Hysol Rudder Fairings.
Details
01-06-2018
4.00
Rudder fairings.
Details
01-05-2018
3.00
Rear baggage compartment
Details
01-04-2018
4.00
Door angles, cargo compartment.
Details
01-03-2018
4.00
Baggage compartment
Details
01-02-2018
5.00
Cargo compartment sewing
Details
01-01-2018
4.00
Baggage compartment
Details
12-31-2017
Cargo compartment
Details
12-13-2017
4.50
Door latches and hinges
Details
12-12-2017
Longeron final installation
Details
12-06-2017
5.00
Longerons, floor boards
Details
12-05-2017
5.00
Seat pan trim, cable interference
Details
12-04-2017
5.00
Console sides, seat pan
Details
12-03-2017
3.50
Rudder cables complete
Details
12-02-2017
3.00
Rudder cable fit and cut
Details
12-01-2017
6.00
Rudder Install
Details
11-30-2017
4.50
Rudder Pedals
Details
11-29-2017
6.00
Rudder Pedals
Details
11-23-2017
Dontrol column bearing
Details
11-15-2017
3.50
Center Console, Floor Boards
Details
11-14-2017
5.50
Rudder Pedal Detent
Details
11-13-2017
3.00
Adjustable rudder pedals
Details
11-06-2017
4.50
Floor Boards, Center Consol
Details
11-05-2017
3.00
Flight controls, floor boards
Details
11-04-2017
8.00
Aileron Elevator Controls
Details
11-03-2017
3.00
Control stick mixer
Details
11-02-2017
6.00
Flight controls.
Details
11-01-2017
3.00
Wing Tip Nutplates, Tailwheel
Details
10-27-2017
3.50
Landing gear
Details
