Dan's Web Site
Work Logs Found: 294
Category Work Time: 460 Hours
 Date
Hours
Work Log Summary
Details
 01-01-2007
0.50
Drill, Debur, Dimple, Rivet Nutplates for Access C
Details
 05-23-2005
Install Control Stick Arm; Andair Valve
Details
 03-20-2005
3.00
Edge Prep - Misc Forward Covers
Details
 03-13-2005
3.00
Bend Heat Baffle Louvre's; Edge Prep
Details
 03-12-2005
0.50
Install Nutplates-Recess and Heat Baffle
Details
 03-12-2005
1.50
Drill Forward Covers -Fuel, Heat, Recess
Details
 03-11-2005
0.50
Fuel Selector Plate; F982E Access Plate
Details
 03-11-2005
F782 Baffle - Drill/Rivet to Cover
Details
 03-06-2005
Rivet F741 Tunnel Cover
Details
 03-03-2005
1.50
Fabricate F741 Tunnel Cover
Details
 02-27-2005
Rivet Seat Floors; Cleco Forward Floors
Details
 02-26-2005
Debur Seat Ribs, Cleco Floors, Rivet
Details
 02-25-2005
2.75
Rivet Seat Hinges to Floors; Edge Prep
Details
 02-25-2005
0.25
Dimple Nutplates for Seat Floors
Details
 02-24-2005
Seat Floors: Cut/Drill Hinges and Pins
Details
 02-24-2005
Debur Seat Pans; Bolt Rear Spar Spacers
Details
 02-23-2005
0.50
Debur / Edge Prep Aft Tunnel Cover
Details
 02-23-2005
3.50
Canopy Rails: Rivet / File to Contour
Details
 02-23-2005
Canopy Rails: Edge Prep
Details
 02-22-2005
1.50
F705 - Rivet Tip Up Angle & Gusset
Details
 02-22-2005
2.50
Edge Prep Baggage Panels; Rivet Blocks
Details
 02-22-2005
1.50
Debur/Dimple Canopy Side Rails/Longerons
Details
 02-21-2005
3.00
Install Nutplates on F706 for Rear Wall
Details
 02-21-2005
Drill Rear Baggage Wall to F706
Details
 02-21-2005
Cut, Drill Shoulder Harness Wear Blocks
Details
 02-06-2005
0.50
Bolt Shoulder Harness Cables to Brackets
Details
 02-05-2005
0.50
Bolt Shoulder Harness Anchors
Details
 02-04-2005
2.50
Rivet Top Skins with Matt
Details
 02-04-2005
0.25
More Fun Pictures of Top Skins Riveted
Details
 02-04-2005
0.25
Details
 01-30-2005
Rear Baggage Wall - Drill for Nutplates
Details
 01-27-2005
Rivet Left Baggage Floor;Radius Rear Wal
Details
 01-26-2005
3.00
Rivet Baggage Floors
Details
 01-26-2005
4.00
Debur, Dimple, Edge Prep, Alodine Floors
Details
 01-25-2005
0.50
Drill Baggage Floors to F706 & Side Covr
Details
 01-22-2005
0.25
First Time Inside of Plane !
Details
 01-22-2005
Debur/Rivet F750 Baggage Side Covers
Details
 01-16-2005
Install Static Tubing / Wiring Conduit
Details
 01-16-2005
Cleco Aft Top Skins; Prime Fuel Tank Bkt
Details
 01-15-2005
Prime Top Skins
Details
 01-15-2005
0.50
Intall Rudder Cable Adel Clamps
Details
 01-15-2005
0.50
Install Static Ports - Pop Rivets
Details
 01-15-2005
Install Rudder Cables and Fairings
Details
 01-09-2005
Prime J-Channels; Edge Prep Top Skins
Details
 01-09-2005
Debur/Dimple J-Channels; Drill Skins
Details
 01-09-2005
Debur/Dimple Aft Top Skins
Details
 01-07-2005
0.75
Rivet Bellcrank Support and Top Rib
Details
 01-07-2005
0.75
Remove Top Skins; Rivet Armrests
Details
 01-07-2005
1.50
Debur / Dimple Bulkheads
Details
 01-06-2005
Match Drill Top Skins
Details
 01-06-2005
0.50
Drill F707B Angle to F707 Bulkhead
Details
 01-05-2005
1.50
Rivet F709 Bulkhead; Insert J-Channels
Details
 01-05-2005
0.25
Pictures of Top Skins Clecoed to Fuselag
Details
 01-05-2005
0.25
Pictures of Me and My Fuselage
Details
 01-05-2005
1.50
Cleco Aft Top Skin/Drill to J-Channels
Details
 01-03-2005
Rivet Gussets:Firewall,Bulkheads,Longero
Details
 01-03-2005
Finish Riveting Aft Deck and Spacers
Details
 01-02-2005
Begin Riveting Aft Deck/Spacers to Longe
Details
 01-01-2005
Wash, Alodine, Prime Gussets, Aft Deck
Details
 12-31-2004
Debur Longerons, Bulkheads, Firewall
Details
 12-31-2004
1.50
Debur Aft Deck and Spacers
Details
 12-29-2004
Debur Gussetts
Details
 12-25-2004
More Leveling; Drill Aft Deck
Details
 12-25-2004
Level the Fuselage
Details
 12-25-2004
Drill Seatbelt Anchors, Rails, & Gussets
Details
 12-24-2004
Rivet Side Skins to Longerons
Details
 12-24-2004
Rivet Aft Side Skins to Aft Bulkheads
Details
 12-23-2004
Rolled the Canoe Over!
Details
 12-23-2004
4.00
Rivet Left Side
Details
 12-23-2004
3.00
Rivet Left Side
Details
 12-22-2004
3.00
Rivet Right Side
Details
 12-22-2004
3.00
Rivet Right Side
Details
 12-21-2004
8.00
Rivet Bottom and Part of Right Side
Details
 12-21-2004
0.25
Details
 12-01-2004
1.75
Fabricate F695, F757 Gussets
Details
 11-29-2004
Cleco Floor Stiffeners;Rivet to Brackets
Details
 11-28-2004
Prime Forward Bottom Skin
Details
 11-28-2004
0.25
Cleco Forward Bottom Skin to Fuselage
Details
 11-28-2004
Alodine Bottom Skin; Drill Out Rivets
Details
 11-27-2004
Swap Nutplates, Rivet Stiffeners to Fire
Details
 11-27-2004
Rivet F796C Bulkheads to Longerons
Details
 11-27-2004
Cleco Forward Fuselage Structure
Details
 11-26-2004
Rivet Clips to Stiffeners; Rivet Gussets
Details
 11-26-2004
1.50
Aux Fuel Pump Bracket; Rivet
Details
 11-25-2004
Prep/Prime Steps and Aux Fuel Bracket
Details
 11-21-2004
3.00
Firewall: Debur/Dimple/Edges, Brackets
Details
 11-20-2004
Right Side Skin: Edges, Rivet Side Plate
Details
 11-20-2004
0.50
Ream 1/4" Holes in Aft F704 for Spacers
Details
 11-20-2004
0.50
Cleco Right Side Skin to Fuselage
Details
 11-20-2004
0.50
Cleco Forward F704 Bulkhead to Fuselage
Details
 11-20-2004
Bolt Control Column Brackets to Aft F704
Details
 11-20-2004
0.50
Baggage Ribs: Rivet Nutplates; Cleco
Details
 11-19-2004
0.25
Rivet Gear Attach Web to F902 Bulkhead
Details
 11-19-2004
3.50
Debur/Dimple Right Side Skin
Details
 11-19-2004
0.50
Cleco Left Side Skin to Fuselage
Details
 11-19-2004
0.75
Alodine Left Side Skin; Rivet Side Plate
Details
 11-18-2004
1.50
Rejoin Center Section to Aft Section
Details
 11-18-2004
F704:Countersink for Double Flush Rivets
Details
 11-18-2004
Countersink/Debur Side Plates; Prime
Details
 11-18-2004
Countersink F705; Tap Seat Ribs; Spacers
Details
 11-17-2004
0.50
Longeron's: Rivet Keeper Rivets
Details
 11-17-2004
1.50
Center Section: Debur / Dimple
Details
 11-17-2004
Aft Fuselage: Debur/Dimple/Flip
Details
 11-16-2004
6.00
Longerons: Countersink, Alodine, Prime
Details
 11-16-2004
F706 Bulkhead: Debur/Dimple/Rivet
Details
 11-15-2004
Remove Center Section
Details
 11-15-2004
5.00
Left Side Skin: Debur, Dimple, Edges
Details
 11-15-2004
Edge Prep Armrests; Remove Left Skin
Details
 11-14-2004
1.50
More Fuselage Prep Work
Details
 11-13-2004
1.75
Details
 11-10-2004
3.00
Wash, Alodine, Prime Forward Components
Details
 11-10-2004
3.00
Countersink Gussets, Stiffeners, Plates
Details
 11-09-2004
5.00
Edge Prep, Wash, Alodine, Prime
Details
 11-09-2004
3.00
Debur/Dimple/Edge Prep Bottom Skin
Details
 11-08-2004
1.50
Right Step: Drill Blocks to Tube / Rib
Details
 11-08-2004
1.50
Left Step: Drill Blocks to Tube / Rib
Details
 11-08-2004
1.50
Drill Baggage Side Covers
Details
 11-07-2004
Right Step: Taper / Bend Plate
Details
 11-07-2004
0.50
Match Drill F722/724 Baggage Ribs
Details
 10-26-2004
1.75
Right Step: Drill Plate and Side Skin
Details
 10-24-2004
1.75
Left Step: Drill Side Skin; Install Ribs
Details
 10-23-2004
Left Step: Mark and Drill the Plate
Details
 10-23-2004
0.50
Left Step: Enlarge Hole in Side Skin
Details
 10-22-2004
1.50
Rudder/Brake Pedals:Drill Center Support
Details
 10-22-2004
1.50
Rudder/Brake Pedals: Drill to Stiffeners
Details
 10-21-2004
Rudder/Brake Pedals: Cut/Drill Blocks
Details
 10-21-2004
Brake Pedals: Install on Rudder Pedals
Details
 10-20-2004
0.75
Brake Pedals: Alodine Pen / Rivet
Details
 10-19-2004
0.50
Brake Pedals: Alumaprep Parts
Details
 10-18-2004
1.50
Brake Pedals: Edge Prep
Details
 10-17-2004
1.75
Brake Pedals: Drill Angles/Side Plates
Details
 10-17-2004
1.75
Brake Pedals: Countersink / Debur
Details
 10-03-2004
0.25
Countersink Bottom Firewall Angle
Details
 10-02-2004
Countersink Floor Stiffeners
Details
 10-01-2004
0.50
Trim F704 Flanges for Main Gear
Details
 10-01-2004
0.50
Remove Floor Stiffeners & Bottom Skin
Details
 10-01-2004
0.50
Match Drill Forward Bottom Skin
Details
 10-01-2004
0.50
Match Drill Floor Stiffeners to Brackets
Details
 09-30-2004
1.75
Forward Section: Drill Floor Stiffeners
Details
 09-29-2004
Drill Right Fuselage Forward Components
Details
 09-29-2004
Details
 09-29-2004
Details
 09-28-2004
Drill Left Fuselage Forward Components
Details
 09-28-2004
Details
 09-28-2004
Details
 09-27-2004
0.50
Fabricate Right Lower Longeron
Details
 09-24-2004
Fabricate Attach Strips and Clips
Details
 09-23-2004
2.50
Left Forward Fuselage: Tailor Fit Parts
Details
 09-21-2004
1.50
Fabricate F684 Gussets
Details
 09-20-2004
Cut Bottom Skin for Right Main Gear
Details
 09-20-2004
Cut Bottom Skin for Left Main Gear
Details
 09-19-2004
Drill Longerons to Upper Steel Brackets
Details
 09-19-2004
0.50
Drill Firewall to Side Skins
Details
 09-19-2004
1.25
Drill Baggage Ribs; Left Side Skin
Details
 09-19-2004
Cleco and Drill Firewall to Side Skins
Details
 09-18-2004
Drill Left Longeron
Details
 09-13-2004
0.50
Match Drill Right Side Skin
Details
 09-13-2004
3.00
Drill Right Longeron
Details
 09-13-2004
0.50
Cut Right Longeron
Details
 09-08-2004
Flute/Cleco Arm Rests; Cut Left Longeron
Details
 08-29-2004
Steps: Cut Corner Ribs; Drill Blocks
Details
 08-25-2004
0.50
Cleco Left Side Skin Fuselage
Details
 08-25-2004
0.50
Bend Right Side Skin
Details
 08-25-2004
Bend Left Side Skin; Cleco to Fuselage
Details
 08-24-2004
Drill Hole for Rigt Step; Drill Out Rive
Details
 08-23-2004
Drill Hole for Left Step; Cleco Side Ski
Details
 08-21-2004
Rivet Tail Cone
Details
 08-21-2004
Notch and Install Right Longeron
Details
 08-21-2004
0.25
Join Center Section to Aft Section
Details
 08-21-2004
0.25
Details
 08-20-2004
Notch and Install Left Longeron
Details
 08-20-2004
2.50
Aft Section: Finish Riveting Skins
Details
 08-08-2004
2.50
Center Section: Outboard Seat Ribs
Details
 08-08-2004
0.50
Center Section: Debur/Dimple for Ribs
Details
 08-07-2004
Center Section: Left Outboard Seat Rib
Details
 07-18-2004
Center Section: Right Outboard Seat Rib
Details
 07-18-2004
Aft Section: Rivet Bottom Skin
Details
 07-18-2004
0.25
Aft Section: Bottom Skin Pictures
Details
 07-09-2004
1.50
Center Section: Drill Floor Panels
Details
 07-09-2004
1.50
Details
 07-07-2004
0.50
Center Section: Cleco Floor Panels
Details
 06-28-2004
1.50
Center Section: Rivet Bottom Section
Details
 06-26-2004
Details
 06-21-2004
1.50
Details
 06-20-2004
Details
 06-20-2004
0.50
Center Section: Cleco Bottom Skin
Details
 06-19-2004
2.50
Center Section: Debur/Dimple Bottom Skin
Details
 06-09-2004
2.50
Center Section: Bolt Ribs, Debur Skin
Details
 06-08-2004
1.50
Center Section: Rivet Seat Ribs to Bulkh
Details
 06-08-2004
2.50
Center Section: Rivet Ribs to F705 Bulkh
Details
 06-08-2004
0.50
Center Section: Debur/Dimple Forward Bul
Details
 06-08-2004
0.50
Center Section: Debur/Dimple F705 Bulkhe
Details
 06-04-2004
0.75
Center Section: Debur Dimple Aft Bulkhea
Details
 06-04-2004
0.25
Details
 06-03-2004
3.00
Seat/Baggage Ribs: Prep and Prime
Details
 06-01-2004
0.50
Baggage Ribs: Debur and Dimple
Details
 05-31-2004
Seat/Baggage Ribs: Nutplates
Details
 05-12-2004
Center Section: Prime 4 More Seat Ribs
Details
 05-11-2004
Center Section: Prime 4 Seat Ribs
Details
 05-11-2004
1.50
Center Section: Debur/Dimple Seat Ribs
Details
 05-10-2004
Center Section: Modify Ribs for Steps
Details
 05-10-2004
3.00
Center Section: Match Drill
Details
 05-10-2004
Center Section: Disassemble / Prep
Details
 05-02-2004
0.75
Center Section: Right Corner Rib
Details
 05-02-2004
0.75
Center Section: Left Corner Rib
Details
 04-27-2004
Center Section:Modify Rib Flanges-Wiring
Details
 04-27-2004
0.50
Center Section: Unibit F704 - Battery
Details
 04-27-2004
Center Section: Cleco Ribs/Bottom Skin
Details
 04-26-2004
Center Section: Prep Seat/Baggage Ribs
Details
 04-26-2004
Details
 04-26-2004
0.50
Center Section: Cleco Seat/Baggage Ribs
Details
 04-24-2004
3.75
Center Section: Prep Seat Ribs
Details
 04-23-2004
0.50
Center Section: Modify 4 Seat Ribs
Details
 04-23-2004
0.50
Details
 04-23-2004
0.50
Center Section: Debur/Polish Spacers
Details
 04-22-2004
Center Section: Fabricate Spacers
Details
 04-20-2004
3.00
Fabricate Rudder Stops, Misc Angles
Details
 04-01-2004
3.50
Rivet Tailcone; Cleco Aft Fuselage
Details
 03-31-2004
Aft Side Skins:Prime/Dimple Rudder Cable
Details
 03-31-2004
1.50
Aft Bottom Skin:Prime, Touchup Bulkheads
Details
 03-30-2004
Bulkheads:Enlarge Longeron Slots/Dimple
Details
 03-30-2004
1.50
Details
 03-29-2004
7.00
J-Channels: Debur/Dimple/Prime
Details
 03-28-2004
3.25
J-Channels - Debur Holes / Edges
Details
 03-07-2004
3.25
Right Aft Side Skin - Dimple/Debur Edges
Details
 03-07-2004
2.50
Bottom Aft Skin - Dimple/Debur Edges
Details
 03-06-2004
0.50
Remove Right Aft Side Skin / Plastic
Details
 03-06-2004
2.50
Left Aft Side Skin - Dimple/Debur Edges
Details
 02-29-2004
3.75
Match Drill Aft Fuselage Debur Left Skin
Details
 02-28-2004
0.25
Fabricate / Drill F728B Angle
Details
 02-28-2004
1.75
Cleco Tailcone to Aft Fuselage
Details
 02-09-2004
Drill and Cleco J-Channels
Details
 02-01-2004
4.00
Longerons: Downward Bends and Twist
Details
 02-01-2004
4.00
Cut J-Channels; Cleco Aft Fuselage
Details
 01-31-2004
5.00
Longerons: Shallow Bends
Details
 01-31-2004
1.50
Longerons: Drill F721B Aft Canopy Decks
Details
 01-31-2004
1.50
Bulkheads: Prime and Rivet
Details
 01-30-2004
Longerons: Cut to Length; Prime Bulkhead
Details
 01-28-2004
1.50
Longerons: Cut End Notches
Details
 01-27-2004
2.25
Bulkheads: Prep F709,11,12; Rivet 707,10
Details
 01-26-2004
Bulkheads: Prime F707/710, Rivet F706/08
Details
 01-25-2004
1.50
F707/F710 Bulkheads: Debur/Polish Edges
Details
 01-25-2004
F706/F708 Bulkheads; Wash and Prime
Details
 01-25-2004
0.50
F705 Bulkhead; Drill Flap Blocks
Details
 01-25-2004
3.00
F705 Bulkhead: Rivet Bars; Bolt Brackets
Details
 01-24-2004
Prime Bulkhead Reinforcement Bars
Details
 01-22-2004
F712 Bulkhead: Fabricate Tie Down
Details
 01-21-2004
1.75
F705 Bulkhead: Fabricate F605C Bars
Details
 01-20-2004
F711 Bulkhead: Drill/Taper Bars, Angle
Details
 01-19-2004
1.50
F711 Bulkhead: Fabricate Bars
Details
 01-19-2004
1.50
F710 Bulkhead: Fabricate Angle; Drill
Details
 01-19-2004
0.50
F706 Bulkhead: Rivet Bottom / Bellcrank
Details
 01-18-2004
3.00
F707/F708 Bulkheads: Cleco/Drill
Details
 01-18-2004
2.25
F706 Bulkhead: Cleco/Drill Assembly
Details
 01-17-2004
3.00
F706 Bulkhead: Flute / Polish Edges
Details
 01-17-2004
0.50
F706 Bulkhead: Drill Bellcrank
Details
 01-17-2004
2.50
F706 Bulkhead: Bellcrank Structure
Details
 01-12-2004
1.50
F705 Bulkhead: Rivet Top & Sides
Details
 01-12-2004
0.50
F705 Bulkhead: More Riveting
Details
 01-11-2004
3.00
F705 Bulkhead: Wash and Prime
Details
 01-10-2004
F705 Bulkhead: Debur
Details
 01-09-2004
F705 Bulkhead: Drill Top Angles
Details
 01-09-2004
0.50
F705 Bulkhead: Countersink's
Details
 01-09-2004
F705 Bulkhead: Cleco and Match-Drill
Details
 01-08-2004
F705 Bulkhead: Fabricate Parts
Details
 01-08-2004
0.50
F705 Bulkhead: Drill Top Parts
Details
 01-08-2004
F705 Bulkhead: Drill Seat Belt Brackets
Details
 01-08-2004
F705 Bulkhead: Bend/Drill Top Parts
Details
 01-07-2004
3.00
F705 Bulkhead: Clamp/Drill Bottom Sectio
Details
 01-07-2004
5.00
Center Section: Rivet Bulkheads
Details
 01-06-2004
Center Section: Nutplates
Details
 01-06-2004
Center Section: Debur/Rivet Stiffeners
Details
 01-06-2004
Center Section: Countersink Bars and Web
Details
 01-06-2004
Center Section: Cleco/Drill Bulkheads
Details
 01-05-2004
1.50
Wash/Prime Center Section Parts
Details
 12-28-2003
0.50
Center Section: Drill Stiffeners
Details
 12-28-2003
Center Section: Drill Cover Brackets
Details
 12-28-2003
2.50
Center Section: Control Column Brackets
Details
 12-27-2003
Center Section - Drill for Snap Bushings
Details
 12-27-2003
Back-Rivet Firewall
Details
 12-26-2003
0.50
Cleco Firewall Together
Details
 12-26-2003
Back-Rivet Firewall
Details
 12-25-2003
Wash and Prime Firewall Components
Details
 12-13-2003
1.50
Firewall: Finish Countersinking
Details
 12-02-2003
Countersink Firewall Components
Details
 11-30-2003
1.50
Firewall: Debur/Countersink Angles
Details
 11-30-2003
Debur / Dimple Firewall; Dimple Recess
Details
 11-29-2003
3.00
Fabricate / Cleco / Match-Drill Firewall
Details
 11-29-2003
Drill Recess to Firewall; Begin Deburrin
Details
 11-28-2003
1.50
Fabricate F-601J Firewall/Floor Angles
Details
 06-18-2003
Inventory - Unpacking
Details
 06-18-2003
Inventory - Move to Crawl Space
Details
 06-18-2003
Inventory - continued
Details
 06-18-2003
Fuselage Kit Arrives; Inventory
Details
