Randalls Web Site
Work Logs Found: 584
Category Work Time: 2424 Hours
 Date
Hours
Work Log Summary
Details
 05-15-2010
2.60
Main Fairings
Details
 05-14-2010
6.30
Main gear leg fairings
Details
 05-13-2010
5.20
Main gear legs
Details
 05-12-2010
4.70
Main wheel fairings
Details
 05-11-2010
3.70
Nose gear
Details
 05-08-2010
2.90
Flaps
Details
 05-07-2010
5.20
Nose fairing
Details
 05-06-2010
3.80
Wheel fairing fitting
Details
 05-05-2010
3.30
Muffler alterations
Details
 05-04-2010
2.90
Muffler alterations
Details
 04-28-2010
5.10
Nose Fairing
Details
 04-27-2010
5.50
Wheel Pants
Details
 04-25-2010
3.90
Main Fairings
Details
 04-24-2010
1.90
Details
 04-23-2010
3.50
Main Fairings
Details
 04-22-2010
1.90
Flight testing
Details
 04-20-2010
3.80
Flight testing
Details
 04-19-2010
2.40
Flight testing
Details
 04-15-2010
2.10
Flight testing
Details
 04-14-2010
4.60
Flaps, ailerons, prop
Details
 04-13-2010
2.30
Prop, empennage
Details
 04-09-2010
4.40
Brackets, prop install
Details
 04-08-2010
2.20
Bracket layouts
Details
 04-07-2010
3.20
Details
 04-06-2010
3.20
Installing Gen 3
Details
 04-05-2010
1.60
Removed Gen 1
Details
 03-31-2010
1.70
First Flight
Details
 03-28-2010
0.80
Fuel
Details
 03-28-2010
0.01
First Flight
Details
 03-24-2010
2.20
Main wheel fairings
Details
 03-23-2010
1.20
More documentation for aircraft pouch
Details
 03-22-2010
2.10
Paperwork
Details
 03-21-2010
2.10
Hi-speed testing
Details
 03-20-2010
1.10
Fuel & Taxi Testing
Details
 03-18-2010
5.10
Taxi Testing
Details
 03-17-2010
6.10
Low speed taxi testing
Details
 03-16-2010
3.80
Details
 03-16-2010
0.10
Headset
Details
 03-15-2010
2.20
Batteries, misc
Details
 03-13-2010
2.80
Cleaning
Details
 03-12-2010
2.30
Insurance
Details
 03-11-2010
4.70
Canopy, seals
Details
 03-10-2010
5.20
Inspection Panels
Details
 03-08-2010
5.20
Seating and belts
Details
 03-07-2010
3.90
Carpeting
Details
 03-06-2010
2.60
Trim Panels
Details
 03-06-2010
2.10
More trim finishing
Details
 03-05-2010
2.50
Panels and trim
Details
 03-05-2010
3.60
Details
 03-04-2010
0.10
IT'S HERE.. FINALLY !!!!!
Details
 03-04-2010
2.10
Details
 03-03-2010
2.90
Seals and misc.
Details
 03-03-2010
2.70
Panel installation
Details
 03-02-2010
1.40
Labelling and tire pressures.
Details
 03-02-2010
1.20
Label replacements.
Details
 03-02-2010
2.10
Cover installations
Details
 03-01-2010
3.60
Panels & Wheel Torque
Details
 03-01-2010
3.10
Panel Installs
Details
 02-22-2010
5.00
Floor panels
Details
 02-21-2010
3.10
Wing roots
Details
 02-12-2010
3.20
Fairings
Details
 02-11-2010
4.80
Fairings
Details
 02-10-2010
2.10
Touchups
Details
 02-09-2010
2.40
Paperwork for Inspection
Details
 02-09-2010
6.10
Inspection
Details
 02-08-2010
3.80
Readying for inspection
Details
 02-07-2010
2.30
Washing
Details
 02-06-2010
3.60
Engine Testing
Details
 02-04-2010
2.10
Checking
Details
 01-29-2010
1.10
Batteries
Details
 01-25-2010
2.20
Testing systems
Details
 01-23-2010
4.70
Forward cowl, engine cowl
Details
 01-22-2010
2.20
Forward cowl
Details
 01-21-2010
2.40
Wire tie ups
Details
 01-19-2010
5.70
EIS, CofG, Start
Details
 01-16-2010
3.10
Electrical system
Details
 01-15-2010
2.80
Fuel, MAP
Details
 01-14-2010
2.70
EIS Fuel Guages
Details
 01-12-2010
1.60
ELT
Details
 01-07-2010
2.20
EIS
Details
 01-06-2010
2.10
EIS programming
Details
 01-02-2010
0.70
Details
 12-30-2009
2.10
Checking ranges
Details
 12-23-2009
4.20
EIS Programming
Details
 12-22-2009
3.10
Wiring and installing panel
Details
 12-19-2009
2.30
Finished wiring
Details
 12-17-2009
9.20
Wiring and tweaking
Details
 12-05-2009
3.20
More wiring
Details
 11-30-2009
46.00
Wiring tweaking
Details
 10-19-2009
4.40
Forward Cowl
Details
 10-13-2009
73.00
Miscellaneous wiring
Details
 10-06-2009
2.30
Forward Cowl
Details
 10-05-2009
3.10
Forward Cowl
Details
 10-04-2009
2.70
Engine run & Fuel Calibration
Details
 10-03-2009
2.10
EIS Wiring
Details
 10-02-2009
2.30
Forward Cowling Improvement
Details
 10-01-2009
3.10
Finishing
Details
 09-30-2009
4.40
Finishing
Details
 09-29-2009
6.20
Details
 09-28-2009
3.20
Muffler & Heater
Details
 09-25-2009
2.20
Heating Ducts
Details
 09-24-2009
2.30
Muffler & Heat Ducts
Details
 09-23-2009
5.10
Wiring cleanup
Details
 09-22-2009
3.10
Brakes
Details
 09-21-2009
3.50
Locking Handle
Details
 09-19-2009
3.10
Misc W#iring
Details
 09-18-2009
3.30
Wiring & W&B
Details
 09-17-2009
3.30
Weight & Balance
Details
 09-12-2009
2.80
Wire tie ups.
Details
 09-11-2009
3.30
Timing
Details
 09-10-2009
3.10
Tying off
Details
 09-09-2009
5.10
Wiring cleanup, etc
Details
 09-08-2009
5.50
Engine tuning, muffler work
Details
 09-07-2009
4.60
Cockpit area and engine area
Details
 09-05-2009
3.50
Details
 09-04-2009
3.30
Engine testing and timing
Details
 09-03-2009
3.60
Sensors and trim
Details
 09-03-2009
2.10
FWF Finishing
Details
 09-02-2009
5.70
Little stuff
Details
 09-01-2009
4.30
Water temp sensor SDS & Misc
Details
 09-01-2009
0.10
test
Details
 09-01-2009
2.40
ECM, drain hole
Details
 08-31-2009
3.30
Pitot, static, AOA lines
Details
 08-31-2009
1.70
Labelling
Details
 08-31-2009
0.50
Engine start
Details
 08-29-2009
2.10
Trim
Details
 08-29-2009
1.10
Finishing
Details
 08-29-2009
2.30
EFI
Details
 08-28-2009
1.50
Static & Pitot
Details
 08-28-2009
5.40
SDS EFI
Details
 08-27-2009
5.30
SDS EFI
Details
 08-26-2009
2.70
A/F Guage, plug wires.
Details
 08-22-2009
2.60
Trim wiring
Details
 08-22-2009
4.20
SDS EFI
Details
 08-21-2009
7.20
Sensors and wiring.
Details
 08-21-2009
5.10
Connecting the trimwiring
Details
 08-20-2009
6.20
Muffler and Injectors
Details
 08-19-2009
5.90
SDS EFI system Install
Details
 08-18-2009
5.70
New SDS EFI system
Details
 08-17-2009
1.70
SDS system
Details
 08-15-2009
0.90
Autopilot troubleshooting
Details
 08-14-2009
4.60
Flaps, bezels, autopilot
Details
 08-13-2009
4.30
Trims systems and flaps
Details
 08-12-2009
5.70
Control sticks
Details
 08-11-2009
2.70
Control sticks and Ignition system
Details
 08-10-2009
3.90
Engine diagnostics
Details
 08-08-2009
1.50
Engine miss
Details
 08-07-2009
5.50
Engine miss
Details
 08-06-2009
5.30
Engine miss and Prop
Details
 08-05-2009
5.20
Engine tuning
Details
 08-04-2009
5.20
Misfiring
Details
 07-31-2009
6.20
First Start of Engine
Details
 07-30-2009
10.10
Wire cleanup.
Details
 07-30-2009
4.30
Securing and finishing
Details
 07-29-2009
4.10
Wire routing and cleanup.
Details
 07-29-2009
9.70
Wire cleanup
Details
 07-28-2009
9.20
Wire tie-ins and testing
Details
 07-28-2009
4.70
More tie-ins and EXP Bus rework
Details
 07-27-2009
9.10
Wiring tie-ins
Details
 07-27-2009
4.70
Wiring
Details
 07-25-2009
Panel finishing
Details
 07-24-2009
7.10
Routing and anti-chafing
Details
 07-24-2009
4.10
Panel windup
Details
 07-23-2009
7.70
Wiring, and fuel system.
Details
 07-23-2009
5.50
More panel work
Details
 07-22-2009
6.50
Fuel flows, etc
Details
 07-21-2009
6.10
Tested both tanks
Details
 07-20-2009
4.00
Panel wiring and routing
Details
 07-20-2009
5.00
Brake bleed
Details
 07-19-2009
3.10
Fuel drains
Details
 07-17-2009
6.10
Rudder lite and headset brackets.
Details
 07-16-2009
8.10
Routing wires and lines
Details
 07-15-2009
7.50
More panel wiring.
Details
 07-14-2009
3.80
Routing of wiring and pitot lines.
Details
 07-14-2009
4.10
Panel wiring and wingtip wiring.
Details
 07-13-2009
7.10
Testing and routing
Details
 07-10-2009
7.00
Light and prop controller
Details
 07-09-2009
5.10
Testing lighting system
Details
 07-08-2009
5.90
Breakers and switches
Details
 07-07-2009
2.30
VOR Testing
Details
 07-07-2009
3.70
Layout and drilling
Details
 07-06-2009
5.30
Strobe unit
Details
 07-04-2009
5.10
Checking
Details
 06-30-2009
2.70
Dynon
Details
 06-29-2009
3.90
Dynon
Details
 06-26-2009
9.50
Harnesses for Avionics
Details
 06-24-2009
5.60
Engine wiring
Details
 06-23-2009
7.10
Engine wiring
Details
 06-22-2009
6.60
Engine compartment & prop
Details
 06-20-2009
1.30
Reading of wiring avionics.
Details
 06-20-2009
1.80
OAT
Details
 06-19-2009
2.20
Cooling
Details
 06-19-2009
3.40
Cleaning & Organizing
Details
 06-18-2009
5.70
Instrument panel
Details
 06-17-2009
4.50
Olieker clamps, plugs
Details
 06-17-2009
2.60
Firewall
Details
 06-16-2009
3.20
Fuel rail
Details
 06-16-2009
1.20
Firewall seal
Details
 06-15-2009
5.80
Aileron trim & panel
Details
 06-12-2009
3.20
Control stick wiring
Details
 06-11-2009
1.20
Fuel line
Details
 06-11-2009
2.90
Control stick
Details
 06-10-2009
5.70
Fuel system
Details
 06-09-2009
5.20
Aileron servo & prop
Details
 06-08-2009
3.90
Installed prop
Details
 06-08-2009
2.30
Aileron trim wiring
Details
 06-06-2009
1.10
Electric trim
Details
 06-05-2009
1.70
Strobes
Details
 06-05-2009
Electric roll trim
Details
 06-04-2009
5.30
Right Wingtip
Details
 06-03-2009
6.30
More wiring
Details
 06-02-2009
4.50
Details
 06-01-2009
5.10
EIS Wiring
Details
 05-29-2009
1.20
Routing
Details
 05-29-2009
2.10
Gascolator
Details
 05-28-2009
2.60
ECU and EIS harness routing.
Details
 05-28-2009
2.10
Coolant lines
Details
 05-27-2009
4.70
More figuring
Details
 05-26-2009
2.70
Sensors
Details
 05-26-2009
1.30
Exhaust clearance
Details
 05-25-2009
4.70
Thinking and reading
Details
 05-24-2009
1.10
Removed Instrument Panel
Details
 05-23-2009
4.30
Tracing engine harness
Details
 05-22-2009
2.10
Wiring
Details
 05-22-2009
3.20
Installed Dynon
Details
 05-21-2009
6.10
Installed instruments
Details
 05-21-2009
1.10
Engine mount Bolts
Details
 05-20-2009
5.20
Ailerons and flaps
Details
 05-19-2009
5.70
Ailerons and flaps
Details
 05-18-2009
3.20
Flaps and ailerons
Details
 05-17-2009
1.40
The thought process
Details
 05-17-2009
5.60
Ailerons
Details
 05-16-2009
5.50
Flaps & ailerons
Details
 05-15-2009
4.60
Flaps and ailerons
Details
 05-14-2009
6.20
Wings bolts, ete
Details
 05-13-2009
8.10
Installation of wings.
Details
 05-12-2009
5.70
Elevator and misc
Details
 05-11-2009
6.10
Brakes, alt hold, rudder
Details
 05-09-2009
2.80
Elevator installation
Details
 05-08-2009
5.90
Empennage assembly.
Details
 05-07-2009
3.20
Planning for assembly.
Details
 05-06-2009
2.10
More parts to hangar
Details
 05-06-2009
3.90
Finish painting
Details
 05-06-2009
2.40
Elevator paint
Details
 05-05-2009
4.70
Upper engine cowl
Details
 05-04-2009
1.40
More items to hangar
Details
 05-03-2009
1.50
Tool box
Details
 04-27-2009
2.10
Wings to hangar
Details
 04-25-2009
0.00
Turned 57 today...day off
Details
 04-23-2009
4.20
Moved fuselage for hangar
Details
 04-22-2009
2.80
Reinstalled the engine
Details
 04-21-2009
3.40
Firewall insulation
Details
 04-20-2009
4.70
Finished painting upper fuselage
Details
 04-19-2009
2.30
Naca fitting
Details
 04-19-2009
2.10
Masking fuselage
Details
 04-19-2009
1.50
Loaded up the Jeep for the airport
Details
 04-18-2009
3.70
Rear window
Details
 04-17-2009
2.90
Rear window install
Details
 04-17-2009
1.80
Prepping fuselage.
Details
 04-17-2009
1.70
ELT Shelf
Details
 04-16-2009
4.10
Upper fuselage prep.
Details
 04-16-2009
2.10
Pulled more wire.
Details
 04-15-2009
3.60
Tail cone wiring.
Details
 04-14-2009
0.00
Day Off
Details
 04-13-2009
1.80
Repainted instrument panel
Details
 04-13-2009
2.20
Loom for tail
Details
 04-12-2009
Painted instrument panel
Details
 04-12-2009
2.10
Paint spinner
Details
 04-11-2009
2.70
Riveting trays
Details
 04-11-2009
1.40
Reading on fairings.
Details
 04-11-2009
2.90
Prepping panel and spinner
Details
 04-10-2009
4.90
Fitting Instruments
Details
 04-08-2009
3.10
Interior paint
Details
 04-07-2009
4.90
Finish painting the interior.
Details
 04-06-2009
3.90
Prepping interior for paint
Details
 04-05-2009
0.70
Rolled the fuselage over.
Details
 04-05-2009
2.60
Firewall pentrations and ECU
Details
 04-04-2009
2.10
Cleaned up the masking tape and paper
Details
 04-03-2009
2.60
Prime bottom of fuse and cowlings
Details
 04-03-2009
5.40
Finish paint Fuselage Bottom
Details
 04-03-2009
0.10
Before, during and after colour change.
 04-02-2009
3.20
Masking and prepping
Details
 04-02-2009
2.60
Finish prep and wash
Details
 04-01-2009
2.70
Repaint prep
Details
 04-01-2009
1.90
Nose gear change.
Details
 03-31-2009
4.80
Stripping of primer.
Details
 03-31-2009
3.30
Stripping
Details
 03-30-2009
4.50
Started stripping old colour
Details
 03-30-2009
3.30
Engine removal.
Details
 03-29-2009
5.20
Sealing pinholes
Details
 03-28-2009
0.10
Back from the In-Laws
Details
 03-23-2009
2.60
Spot Putty
Details
 03-22-2009
3.20
Block Sanding
Details
 03-21-2009
3.10
Prep for prime
Details
 03-20-2009
1.50
Instrument Panel Mockup
Details
 03-20-2009
5.00
Finishing Cowling
Details
 03-19-2009
6.70
Cowl hinges
Details
 03-18-2009
5.30
Fitting Cowling
Details
 03-18-2009
2.10
Fitting cowl
Details
 03-17-2009
3.10
Lower cowl finishing
Details
 03-16-2009
3.70
More filling and sanding
Details
 03-16-2009
4.90
Fitting and toggles
Details
 03-15-2009
4.50
Slurry fill in vent areas.
Details
 03-14-2009
3.80
Lower vent finishing
Details
 03-14-2009
1.10
Lower cowl vents
Details
 03-14-2009
2.70
Dynon tray fitting in Instrument Panel
Details
 03-13-2009
2.20
Layups on lower outlet vents
Details
 03-13-2009
3.40
Cutting and lay out.
Details
 03-12-2009
1.80
Radiator intake blanks.
Details
 03-12-2009
2.30
Lower exit vents
Details
 03-12-2009
3.10
Lower cowl flaps
Details
 03-12-2009
Inlet work
Details
 03-11-2009
2.90
Lower cowl exit vents
Details
 03-11-2009
3.80
Honeycomb removal and cleanup.
Details
 03-11-2009
1.80
Cowl opening shaping
Details
 03-10-2009
7.10
More cowling work
Details
 03-09-2009
0.50
Gen 1,2,3,4 oil cowl vent
Details
 03-09-2009
8.10
Designed new oil cowl vent
Details
 03-08-2009
0.80
Oil vent
Details
 03-08-2009
2.10
Horizontal hinge fasteners
Details
 03-08-2009
2.20
Coolant inlets
Details
 03-08-2009
4.10
Botton exit vents
Details
 03-07-2009
2.30
Oil & Rad Vents
Details
 03-06-2009
4.40
Rework coolant openings
 03-06-2009
2.70
New Oil vent
Details
 03-06-2009
0.60
Cowl rework
Details
 03-05-2009
3.30
Repairs
Details
 03-04-2009
4.50
Cooler core
Details
 03-03-2009
0.20
Repairs
Details
 03-03-2009
6.30
Oil cooler vent
Details
 03-02-2009
3.40
Oil door
Details
 03-02-2009
1.10
Fibreglass repair
Details
 03-02-2009
2.30
Exit air
Details
 03-01-2009
1.10
Lower Cowl Fitting
Details
 03-01-2009
5.20
Exit Air Cowl Bracket
Details
 02-28-2009
6.20
Hinge fasteners
Details
 02-27-2009
5.80
Fitting upper cowl
Details
 02-26-2009
7.70
More fitting
Details
 02-25-2009
5.80
Upper cowl
Details
 02-24-2009
4.70
Cowling fitting
Details
 02-23-2009
1.70
Upper cowling
Details
 02-23-2009
2.70
Clear-coated wing
Details
 02-22-2009
3.40
Repainted basecoat
Details
 02-21-2009
3.50
BASE TOUCHUP
Details
 02-20-2009
4.00
Colour sanding
Details
 02-19-2009
5.80
Wet sanding
Details
 02-18-2009
5.60
Repaint
Details
 02-17-2009
3.20
Repaint
Details
 02-12-2009
3.20
Prepped left wing
Details
 02-12-2009
5.40
Painted left wing.
Details
 02-11-2009
5.30
Painted left wing bottom
Details
 02-10-2009
3.20
Prepped left wing
Details
 02-09-2009
6.20
Rt Wing
Details
 02-05-2009
4.60
Buffing
Details
 01-28-2009
5.20
More fitting
Details
 01-27-2009
4.70
More fitting
Details
 01-26-2009
6.70
Cutting & Fitting
Details
 12-31-2008
3.20
Wing tip
Details
 12-30-2008
4.60
Bottom skin
Details
 12-29-2008
2.30
Wingtip lighting
Details
 12-23-2008
3.30
Left wing tip lighting
Details
 12-22-2008
3.60
Left wing tip - Painted
Details
 12-21-2008
4.90
Left wing tip
Details
 12-20-2008
3.90
Autopilot
Details
 12-19-2008
3.80
Auto pilot
Details
 12-18-2008
5.70
Fuel sender & plate
Details
 12-18-2008
3.90
Autopilot
Details
 11-21-2008
7.50
Left wing top.
Details
 11-20-2008
5.70
Under left wing.
Details
 11-19-2008
3.80
Masking
Details
 11-18-2008
4.20
Fuel plate.
Details
 11-17-2008
5.20
Bottom wing skin
Details
 11-05-2008
2.50
Wingtips.
Details
 11-05-2008
3.10
Pitot
Details
 11-04-2008
2.30
Heated pitot.
Details
 10-29-2008
3.50
Pitot
Details
 10-28-2008
4.20
Left wing
Details
 10-27-2008
3.00
Left wing
Details
 10-26-2008
3.80
Pitot
Details
 10-25-2008
Cleaned shop.
Details
 10-24-2008
2.50
Wing tip
Details
 10-23-2008
3.20
Aileron & Vert Stab
Details
 10-18-2008
5.00
Wing tip & rudder
Details
 10-17-2008
4.00
Details
 10-16-2008
4.80
Painted ailerons
Details
 10-14-2008
4.60
Repaint Flaps
Details
 10-13-2008
4.00
Elevators
Details
 10-11-2008
6.70
Painted elevators
Details
 10-10-2008
6.50
Horizontal stabilizer
Details
 10-09-2008
6.80
Sand & Paint Vetical Stabilizer.
Details
 10-08-2008
3.70
Wet sanding.
Details
 10-07-2008
4.50
Sanding
Details
 10-06-2008
4.20
Priming
Details
 10-05-2008
7.90
Priming
Details
 10-04-2008
Scuffing
Details
 10-03-2008
2.50
Wing tips
Details
 09-29-2008
3.80
Wingtip
Details
 09-28-2008
6.80
Wingroot fairings
Details
 09-27-2008
5.00
Wing tips
Details
 09-26-2008
6.70
Wing angles
Details
 09-26-2008
6.70
Wing angles
Details
 09-25-2008
5.50
Wing settings
Details
 09-24-2008
6.20
More wing work
Details
 09-23-2008
7.00
Setup
Details
 09-22-2008
4.50
Installation
Details
 09-16-2008
4.50
Lower Cowling
Details
 09-15-2008
5.00
Fitting
Details
 09-14-2008
3.50
Removed Prop
Details
 09-14-2008
3.30
Fitting
Details
 09-13-2008
3.20
Wing tips
Details
 09-12-2008
2.70
Wing tips
Details
 09-11-2008
5.80
Wing tips
Details
 09-10-2008
5.40
Wing tips
Details
 09-09-2008
4.00
Wing tips
Details
 09-08-2008
3.50
Details
 09-07-2008
3.00
Wing skin
Details
 09-05-2008
6.00
R/S Wiing
Details
 09-04-2008
3.80
Bottom wing panel.
Details
 09-03-2008
3.20
Wiring
Details
 09-02-2008
5.50
Aileron
Details
 09-01-2008
3.50
Ailerons
Details
 08-31-2008
2.70
Fuel senders
Details
 08-30-2008
6.50
Fairings
Details
 08-29-2008
5.50
Wiring
Details
 08-28-2008
1.40
Bottom skin.
Details
 08-28-2008
5.50
Bottom skin.
Details
 08-27-2008
4.50
Skins
Details
 08-27-2008
4.00
Bottom skin.
Details
 08-26-2008
5.00
Paint prep
Details
 08-25-2008
4.00
Paint prep
Details
 08-24-2008
4.00
Prepping for paint.
Details
 08-23-2008
7.00
Prepped hor stab
Details
 08-22-2008
6.50
Aileron fitting
Details
 08-21-2008
5.60
Ailerons
Details
 08-20-2008
6.50
Ailerons
Details
 08-19-2008
0.50
Took wing out of box.
Details
 08-19-2008
6.50
Flaps
Details
 08-18-2008
5.50
Wing tip Lights
Details
 08-17-2008
6.00
Wing tips
Details
 08-16-2008
3.00
Wing tips
Details
 08-15-2008
4.60
Lights
Details
 08-14-2008
3.50
Push pull tubes
Details
 08-14-2008
Landing Light Lenses
Details
 08-10-2008
3.50
Paint prep
Details
 08-09-2008
Prop adjustment
Details
 08-06-2008
2.80
Installed Quinti/Warp
Details
 08-05-2008
11.00
Trip to my other house.
Details
 08-04-2008
4.00
more glass work on emp
 08-03-2008
3.00
more sanding on emp
 08-02-2008
4.00
primed some repairs on emp
 08-01-2008
3.00
epoxy work on hor stab
 07-31-2008
glass work on emp
 07-30-2008
3.50
re-attached horizontal stabilizer
 07-28-2008
3.00
Reading
 07-26-2008
1.60
Cleanup
 07-25-2008
2.50
seating ass'y
 07-24-2008
4.20
seat assembly
 03-13-2008
0.50
Engine start
Details
 02-08-2008
2.50
Fired Egg Subaru up
Details
 05-27-2007
6.70
Seating area
Details
 05-26-2007
4.80
Baggage
Details
 05-25-2007
1.60
Baggage area
Details
 05-24-2007
3.70
Baggage area
Details
 05-23-2007
4.80
Baggage
Details
 05-22-2007
4.20
Baggage
Details
 05-21-2007
9.50
Baggage area
Details
 05-19-2007
6.00
Baggage
Details
 05-18-2007
5.00
Baggage
Details
 05-16-2007
3.50
Tuning
Details
 05-14-2007
4.00
Figuring out panel
Details
 05-10-2007
2.70
Routing
Details
 05-06-2007
4.50
Engine start
Details
 05-06-2007
2.50
Brake Bleed
Details
 02-06-2007
2.40
Canopy screws
Details
 02-06-2007
3.50
Brakes
Details
 02-05-2007
4.70
Main gear
Details
 02-05-2007
5.60
Engine orientation
Details
 02-04-2007
6.50
Rear window
Details
 02-02-2007
6.00
Rear window
Details
 02-01-2007
4.00
Rear Window
Details
 01-31-2007
3.50
Canopy finishing
Details
 01-30-2007
6.00
Canopy Work
Details
 01-29-2007
6.50
Drilling
Details
 01-28-2007
8.00
Canopy drilling
Details
 01-27-2007
1.50
Cleanup
Details
 01-19-2007
4.80
Canopy painting and layout
 01-18-2007
5.80
Drilled C-603
Details
 01-17-2007
6.70
Riveting C-702 to WD-725
Details
 01-16-2007
3.10
Notch mod to C-702
Details
 01-15-2007
6.60
Canopy Prime & Paint
Details
 01-14-2007
6.30
Latch system
Details
 01-13-2007
4.70
Latch system
Details
 01-12-2007
5.30
Canopy gas struts
Details
 01-11-2007
4.90
Canopy gas struts
Details
 01-10-2007
6.10
Canopy fitting
Details
 01-09-2007
5.20
Riveting canopy frame
Details
 01-08-2007
4.70
Canopy fitting
Details
 01-04-2007
7.00
Canopy fitting
Details
 01-03-2007
5.50
Fitting
Details
 12-16-2006
5.00
Canopy fitting
Details
 12-15-2006
5.50
Fit side rails.
 12-13-2006
5.20
Filling C631
Details
 12-12-2006
7.10
Paint prep 631
Details
 12-11-2006
6.30
Spacers
Details
 12-10-2006
4.40
Clearance issues.
Details
 12-09-2006
6.80
Brakes
Details
 12-08-2006
3.40
Nose wheel
Details
 12-07-2006
2.60
Painted nose gear leg.
Details
 10-08-2004
3.50
F904Bulkhead
Details
 09-23-2004
4.10
Centre section
Details
 09-22-2004
7.80
Floor & seats
Details
 09-21-2004
8.80
Riveting floor skin
Details
 09-20-2004
9.00
Seat & Baggage
Details
 09-19-2004
6.00
Centre section floor
Details
 09-18-2004
5.70
Centre section
Details
 09-17-2004
Reading about & starting centre fuselage.
Details
 09-17-2004
6.20
Re-riveting, cleanup shop
Details
 09-16-2004
8.60
Floors and side skins
Details
 09-15-2004
1.20
Aft floor
Details
 09-14-2004
5.00
Riveting
Details
 09-07-2004
6.10
Fuselage work
Details
 09-06-2004
6.50
Details
 09-05-2004
6.10
Longerons & 707 & 708 bulkheads
Details
 09-04-2004
5.50
Longerons
Details
 09-03-2004
2.20
F718 Template
Details
 09-02-2004
3.50
Work area.
Details
 09-01-2004
8.00
705,712,F916
Details
 08-31-2004
5.00
705 & 712
Details
 08-25-2004
2.50
705 & 712
Details
 08-24-2004
3.50
Priming
Details
 08-23-2004
2.80
Alodining
Details
 08-18-2004
6.50
F705a
Details
 08-17-2004
9.50
F904 & F705
Details
 08-11-2004
9.00
F904 Bulkhead
Details
 08-10-2004
5.50
Inspection Day
Details
 08-09-2004
2.50
Pre-inspection
Details
 08-08-2004
1.50
Firewall
Details
 08-07-2004
6.50
Firewall
Details
 08-02-2004
4.70
Firewall
Details
 07-26-2004
3.50
Firewall
Details
 07-22-2004
12.00
Firewall
Details
 07-21-2004
12.00
Firewall
Details
 07-20-2004
4.50
Inventory
Details
 07-18-2004
9.00
Shop
Details
 07-17-2004
9.50
Moved kit to Peterborough.
Details
 07-15-2004
2.50
PICKED UP FUSELAGE KIT.
Details
 05-24-2004
2.70
Elevators
Details
 05-23-2004
4.00
Wedges, trailing edge
Details
 05-22-2004
2.20
Trim tab.
Details
 05-21-2004
5.00
Riveting
Details
 05-19-2004
4.00
Details
 05-18-2004
Details
 05-17-2004
3.00
Details
 05-16-2004
0.50
Priming
Details
 05-15-2004
3.00
Servo
Details
 05-13-2004
3.50
LS elev
Details
 05-08-2004
6.00
ls elev
Details
 05-07-2004
Riveting
Details
 05-04-2004
Rivetting
Details
 04-24-2004
Back-rivetting
Details
 04-21-2004
3.40
Riveting
Details
 04-20-2004
2.30
Elevators
Details
 04-19-2004
2.20
Left Elevator
Details
 04-18-2004
7.50
Elevators
Details
 04-17-2004
7.00
VS, Rudder and rt elevator.
Details
 04-10-2004
3.50
Rivet
Details
 04-09-2004
3.50
Rivet
Details
 04-07-2004
2.50
Rivet
Details
 04-06-2004
2.80
Dimple & c/s
Details
 04-04-2004
5.00
VS
Details
 04-01-2004
1.50
Cleanup
Details
 03-31-2004
6.70
Riveting
Details
 03-26-2004
6.50
Riveting
Details
 03-25-2004
1.50
Priming
Details
 03-21-2004
7.00
HS VS Rudder
Details
 03-10-2004
2.50
VS
Details
 03-09-2004
3.10
HS
Details
 03-07-2004
4.90
rt skin
Details
 03-05-2004
1.90
drill debur
Details
 03-04-2004
6.50
HS
Details
 03-03-2004
Fabrication
Details
 03-02-2004
HS
Details
 03-01-2004
H/S Parts
Details
 02-29-2004
4.50
Unpack & sort
Details
