Kevin Waterfords Web Site
RV-7A
Work Logs Found:
126
Category Work Time:
354 Hours
Date
Hours
Work Log Summary
Details
06-30-2013
4.00
Assemble Firewall
Details
06-07-2013
4.00
Fuselage Kit Arrives
04-10-2013
5.00
Wings Finished
02-18-2013
10.00
Fiberglass Wing Tips
02-10-2013
6.00
02-04-2013
15.00
Wing Tips and Ailerons
12-28-2012
4.00
Installed Taxi/landing light on the right wing
10-27-2012
3.00
Completed the landing light install for the left w
Details
10-07-2012
Cut the opening in the left leading edge for the
Details
09-11-2012
Piano Hinge for the left flap attachment
Details
09-06-2012
3.00
Attached the flaps and aileron to the left wing.
Details
09-01-2012
4.00
Riveting the flap hinge
Details
08-30-2012
3.00
Completed the riveting of the bottom skins on the
Details
08-26-2012
5.00
Riveting the bottom skins on the left wing
Details
11-12-2011
4.00
Fuel tank
Details
11-11-2011
Dimpled Wing skins
Details
04-20-2011
12.00
New Work Shop
Details
09-23-2009
Right Aileron
Details
09-22-2009
Riveting the bottom skins of the right aileron
Details
09-21-2009
Riveting the Right Aileron
Details
09-20-2009
4.00
Riveting the Right wing skin
Details
09-08-2009
Right Aileron
Details
09-07-2009
3.00
Right Aileron
Details
09-06-2009
3.00
Right Aileron
Details
09-05-2009
3.00
Right Aileron
Details
08-31-2009
Began assembling the right aileron
08-30-2009
4.00
Riveting the right wing's bottom skins
08-21-2009
Riveted the flap brace
Details
08-19-2009
Rebuilt the Aileron hinge
Details
08-16-2009
5.00
Riveted the outboard top skin
Details
08-09-2009
6.00
Riveting the Top Skins of the right wing
Details
07-07-2009
3.00
Riveted the outboard section of the leading edge.
Details
07-06-2009
Riveting the outboard section of the leading edge
Details
07-05-2009
Removed 4 rivets in the rear wing spar
Details
06-15-2009
4.00
Right Wing
Details
06-14-2009
3.00
Right Wing Leading Edge
Details
06-09-2009
Replacing rivets on the Right Fuel tank
Details
06-05-2009
6.00
Completing the Right Fuel Tank
Details
06-01-2009
6.00
Right fuel tank
Details
05-30-2009
5.00
Right Fuel Tank
Details
05-26-2009
3.00
Right Fuel Tank
Details
05-20-2009
3.00
Fuel tanks
Details
05-02-2009
EAA Technical Advisor Sign-off
Details
04-27-2009
Right Fuel Tank
Details
04-26-2009
4.00
Right Fuel Tank
Details
04-21-2009
5.00
Sun-N-Fun
Details
04-18-2009
4.00
Right wing leading edge.
Details
04-17-2009
4.00
Right Wing
Details
04-12-2009
4.00
Drilled rivet holes in the skin to full size
Details
04-05-2009
4.00
Right Wing skin drilled hoes to full size
Details
03-29-2009
4.00
Right wing
Details
03-22-2009
4.00
Right wings
Details
03-16-2009
3.00
Main Spars
Details
03-15-2009
4.00
Right Wing
Details
03-14-2009
3.00
Wing Ribs and Spars
Details
02-01-2009
Rear wing spars
Details
11-02-2008
3.00
Left Main Wing Spar
Details
11-01-2008
3.00
Left Main Wing Spar
Details
10-26-2008
3.00
Right main wing spar
Details
10-25-2008
3.00
Preparing the main wing spars
Details
10-23-2008
Build the wing stands
Details
10-20-2008
Inventoried wing kit
10-17-2008
Finished the Empennage
Details
10-16-2008
Trimming the HS to hang the elevators
Details
10-12-2008
Trim Tab Finished
Details
10-10-2008
Trim tab
Details
10-07-2008
Trim Tab
Details
10-06-2008
Trim Tab
Details
10-05-2008
Trim Tab
Details
10-04-2008
Riveting the left elevator.
Details
09-28-2008
Finished the right elevator
Details
09-25-2008
Bendiing the forward edge of the right elevator
Details
09-20-2008
3.00
Riveting the the right and the left elevators
Details
09-19-2008
4.00
Riveting the Right Elevator
Details
09-13-2008
3.00
Left elevator
Details
09-06-2008
3.00
Riveted the stiffners to the left elevator
Details
08-09-2008
Cutting and shaping the new stiffners for the left
Details
08-04-2008
The new stiffners arrive
08-01-2008
0.00
Attended Airventure 2008 at Oshkosh, WI
Details
07-24-2008
Left elevator stiffners
Details
07-18-2008
Right Elevator
Details
07-13-2008
Elevator
Details
07-11-2008
Left Elevator
Details
07-09-2008
Right Elevator
Details
07-06-2008
Right Elevator
Details
07-05-2008
Right Elelvator
Details
06-29-2008
Right Elevator
Details
06-28-2008
1.50
Details
06-27-2008
1.50
Details
06-22-2008
3.00
Details
06-18-2008
Details
06-16-2008
Details
06-15-2008
3.00
Details
06-14-2008
Details
06-03-2008
Rudder-- Dimpling
Details
06-01-2008
0.00
Attended the NE RV Fly-in in Bloomsburg, PA
Details
05-30-2008
1.50
Rudder--More
Details
05-22-2008
Details
05-20-2008
1.50
Rudder--Completed riveting the stiffiners
Details
05-18-2008
1.50
Rudder - More riveting of stiffiners
Details
05-17-2008
5.00
Rudder- Priming and riveting the stiffiners
Details
05-15-2008
1.50
Details
05-14-2008
1.50
Cutting Rudder Stiffners
Details
05-12-2008
1.50
Details
05-11-2008
Vertical Stabilizer
Details
05-08-2008
Vertical Stabilizer
Details
05-06-2008
Vertical Stabilizer
Details
05-06-2008
Horizontal Stabilizer
Details
05-02-2008
Wing Kit Arrives
Details
04-30-2008
1.50
Riveting HS Skins
04-27-2008
Riveting the right HS Skins
Details
04-26-2008
2.50
Riveted the left HS Skin
Details
04-25-2008
3.00
Started riveting the rear HS Spar
Details
04-24-2008
Primed the HS ribs and spars
Details
04-21-2008
3.00
Dimpled and deburred HS parts
04-20-2008
Built the table for the DRDT-2 dimpler device
Details
04-20-2008
Built the spray rack for priming parts
03-13-2008
3.00
More match drilling in HS
Details
03-09-2008
match drilled HS skins
03-08-2008
4.00
Clecoed the HS ribs together
03-03-2008
3.00
Started forming parts for the rear spar.
Details
03-02-2008
Inventoried the Empennage kit
Details
03-01-2008
3.00
Built bench for grinder, drill press, and vise
Details
02-29-2008
Received the RV tool kit
Details
02-29-2008
0.50
Empagenage Kit Arrvies
Details
02-16-2008
3.00
Built the work tables
Details
RV-7A Home
354
205
