Date
Hours
Work Log Summary
Details
06-13-2021
50.00
VP-X and PPS Install
Details
11-11-2020
8.00
Verify component power wiring
Details
06-07-2020
Install Suntail Light
Details
05-31-2020
6.00
Installed Nav/Strobe lights
Details
05-23-2020
12.00
Stick Grip Wiring
Details
05-07-2020
6.00
Install Control Stick Grips (Mechanical)
Details
02-02-2020
3.00
Finish Spinner Fore/Aft Mounts
01-26-2020
6.00
Spinner alignment and match drilling
01-25-2020
12.00
Engine Wiring
Details
01-24-2020
Air Filter Bypass Door Install
Details
12-31-2019
Wire Starter and Alternators
12-07-2019
8.00
Install Vetterman Exhaust Pipes
10-12-2019
Install Engine Oil Cooler
09-01-2019
12.50
Horizontal Induction Install
Details
07-21-2019
8.00
Inlet Ducts and Oil Filler Door
Details
07-13-2019
6.00
Lower Cowl Nosegear Brace
Details
07-04-2019
4.00
Fit and drill side hinges
Details
06-30-2019
7.00
Lower Cowl drilling
Details
06-22-2019
3.50
Lower Cowl Fitting
Details
06-22-2019
Fitting the upper cowl
Details
06-20-2019
Spinner opening prep
Details
06-16-2019
4.00
Firewall side hinge installation
Details
06-15-2019
Cut oil filler access door into upper cowl
06-08-2019
4.00
Propeller surrogate
Details
05-23-2019
15.00
Rework Engine Control Cable brackets
Details
05-18-2019
8.00
Install fuel system components and alternator
Details
05-05-2019
Install Oil lines
Details
05-04-2019
8.00
P-Mag Wiring
Details
04-27-2019
8.00
Mounted Engine to Airframe
Details
04-21-2019
5.00
Throttle Body Installation
Details
04-19-2019
5.00
Throttle and Mixture Brackets onto Engine Sump
Details
04-06-2019
Oil line fittings
Details
03-24-2019
Install Back Up Alternator
Details
03-03-2019
8.00
Prop Governor Installation
Details
02-16-2019
6.00
Engine Dessicant System
Details
02-10-2019
8.00
Uncrate engine
01-21-2019
3.00
Engine Controls installation
Details
01-06-2019
50.00
Lighted Switches Wiring
Details
11-25-2018
12.00
Intercom wiring
Details
11-18-2018
12.00
Finished wiring SkyView Display harnesses
Details
11-12-2018
5.00
Wiring of Skyview Display Harnesses
Details
10-28-2018
3.00
Riveted Firewall Recess
Details
10-27-2018
4.00
Install sound dampener on cockpit side of firewall
Details
10-20-2018
3.00
COMM Antenna installation
Details
10-08-2018
15.00
Instrument Panel Layout
Details
05-28-2018
20.00
More Wiring
Details
04-30-2018
3.00
Fuel Line and Wiring Harness routing
Details
03-31-2018
8.00
Electrical Harness Fabrication
Details
03-24-2018
8.00
Remove Right Fuel Tank
Details
03-22-2018
Fabricated RF cables
Details
03-10-2018
3.00
Elevator AP Servo Bracket Installation
02-11-2018
10.00
Battery Box Fabrication
Details
02-03-2018
6.00
Flap Position Sensor and wiring
Details
01-27-2018
Repaired damaged baggage compartment stringer
Details
01-06-2018
6.00
Wiring harness for Aileron Trim
Details
12-31-2017
3.00
Wing tie-down storage mounts
Details
12-29-2017
8.00
Functional layout
Details
12-26-2017
7.00
Wired Pitot Probe
Details
11-26-2017
12.00
Drilled holes in the firewall
Details
11-24-2017
6.00
Fabricated mounting ribs for VP-X & EMS
Details
10-09-2017
6.00
Located Firewall Penetrations
Details
09-04-2017
3.00
Put in brake fluid
Details
08-27-2017
12.00
Final prep and priming of Landing gear fairings &
Details
08-20-2017
8.00
Prep and prime ldg gear fairings
Details
08-19-2017
Custom fit fairing to nose gear leg
Details
08-18-2017
6.00
Finish Nosegear wheel fairing and align gear leg f
08-16-2017
Finish Nosewheel front fairing
Details
08-15-2017
Nose wheel front fairing fitting
Details
08-14-2017
Nose Gear Fairing Fitting
Details
08-13-2017
4.00
Nosewheel Breakout Force and Fairing prep
Details
08-04-2017
4.00
Nosewheel Installation
Details
06-12-2017
2.50
Installed Intersection Fairings
Details
06-10-2017
4.00
Wheel Fairing nutplates and riveting
Details
06-04-2017
9.00
Main Wheel Fairings
Details
05-21-2017
4.00
Main Gear Fairing "Fingers" and Wheel Pants
Details
05-20-2017
Finish making Main Gear Leg Fairings
Details
01-16-2017
Finished brakes
01-13-2017
3.00
Countersunk gear fairings; put airplane on the Mai
01-10-2017
Drilled the gear fairing hinge
01-08-2017
Trimmed the hinge material and laid out the rivet
01-03-2017
3.00
Prepared main gear fairings for trimming
Details
01-01-2017
3.00
Repacked Main Wheel bearings
Details
11-26-2016
Rivet aft upper skin to bulkheads and longerons
Details
07-31-2016
10.00
Canopy bow fiberglass molding
Details
07-03-2016
6.00
Fuel pickup safety service bulletin
Details
06-26-2016
20.00
Complete Right Wing Tip
Details
05-09-2016
3.00
Completed Right Wing Tip attach points
Details
04-25-2016
Installed tip rib
Details
04-24-2016
Match-drilled right wing tip to wing
Details
04-23-2016
6.00
Right wing light kit complete
Details
04-20-2016
3.00
Right Wing Light Cut out
Details
04-16-2016
3.00
finish cleanup of left wing
Details
04-05-2016
Install foam rib in left wingtip
Details
03-20-2016
8.00
Left Wing tip fairing; SB06-2-23
Details
03-06-2016
5.00
Left wingtip epoxy and tip lens install
Details
03-02-2016
Finished installing nutplates on left tip
02-28-2016
6.00
Match-drill left wing tip
Details
02-13-2016
4.00
Completed Left Wing Landing Light Kit
12-27-2015
4.00
Hung Rudder and Elevators
Details
12-23-2015
4.00
Primed Elevators and Rudder
Details
12-21-2015
Painting Prep
Details
12-20-2015
Final Sanding of Rudder and Elevators
Details
12-19-2015
4.00
Epoxy Top Coat
Details
12-18-2015
4.00
Sanding and Filling!
Details
12-17-2015
Applied Filler to Elevators and Rudder
Details
12-16-2015
Rudder, Elevator Sanding
Details
12-10-2015
HS Tip sanding
Details
12-09-2015
Sanding the HS Tips
Details
11-01-2008
5.00
Riveted foreward subpanel assembly
Details
03-16-2008
4.00
Wheel Fairing bracket nutplates
Details
03-15-2008
4.00
Main Landing Gear Assembly
Details
03-09-2008
Installed Engine mount
Details
03-08-2008
4.00
Assembled nosewheel and tire
Details
03-07-2008
3.00
Assembled Main Wheels and Tires
03-02-2008
3.00
Drilled 6 engine mount attach points
12-30-2007
8.00
Fuel & Brake line close out
Details
12-26-2007
7.00
Fuel & Brake Line installation
Details
12-23-2007
4.00
Fuel & brake supply line fab
Details
12-22-2007
3.00
Fabricated Fuel Pump Lines
Details
12-15-2007
5.00
Fuel Pump Cover Assembly
Details
12-13-2007
Fuel Pump Cover
Details
12-12-2007
1.50
Fuel Pump Cover work
Details
12-02-2007
6.00
Fin. Ail. Trim, Began Fuel Pump
Details
12-01-2007
2.50
Aileron Trim
Details
11-27-2007
3.00
Aileron Trim
Details
11-24-2007
3.00
Aileron Trim Work
Details
11-12-2007
8.00
Aileron Trim, ele. pushrod, static sys
Details
11-10-2007
Miscellaneous Riveting
Details
11-07-2007
Tail section access plates
Details
11-05-2007
1.50
Prepared Static Line Ports
Details
10-17-2007
3.00
Finished painting cabin parts
Details
10-15-2007
10.00
Riveted seatbacks; painted cabin
Details
10-15-2007
5.00
Cabin area priming
Details
10-13-2007
12.00
Prep Fuselage for priming
Details
10-08-2007
7.00
Finished instrument panel mounting
Details
10-06-2007
5.00
Forward Top skin
Details
10-04-2007
1.50
Subpanel Work
Details
09-29-2007
10.50
F768 Subpanel assembly
Details
09-25-2007
2.50
Finished 703B angle
Details
09-19-2007
1.50
Forward Cabin work
Details
09-18-2007
Foreward cabin work
Details
09-08-2007
12.00
Fixed Problem with Cabin Frame
Details
09-03-2007
6.00
Finished Emp Fitting; worked Cabin Frame
Details
09-02-2007
4.50
Empennage Fitting
Details
09-01-2007
8.00
Empennage Fitting
Details
08-31-2007
3.50
Drill Elevator Horns; unpack Finish Kit
Details
08-25-2007
6.00
Aft-End Upper Fuselage prep work
Details
08-24-2007
6.00
Made F790 elevator pushrod
Details
08-23-2007
9.00
Cabin Frame Construction Completed
Details
08-22-2007
6.00
Details
08-21-2007
4.00
Details
08-19-2007
4.00
Details
08-18-2007
3.00
Wing Removal
Details
08-14-2007
1.50
Misc Wing-mate cleanup tasks
Details
08-11-2007
6.00
Fuel line installation
Details
08-09-2007
9.00
Fuel Line installation
Details
08-07-2007
4.00
Finished rigging ailerons and flaps
Details
08-05-2007
3.00
Cut holes in fuselage for flap pushrods
07-29-2007
3.50
Rigged ailerons
Details
07-28-2007
4.00
Fuel Tank Attach Bracket
Details
07-27-2007
1.50
Drilled Rear Spar Attach point
Details
07-24-2007
2.50
Measured Wing Sweep and Incidence
Details
07-21-2007
4.00
Wings Mated!
Details
07-19-2007
Finished prep for wing mate
Details
07-17-2007
Wing Mate Prep Work
Details
07-16-2007
Wing Mate Prep Work
Details
07-08-2007
10.00
Install Ldg Gear Mounts
Details
07-05-2007
Fit Ldg Gear Legs to Mounts
Details
07-04-2007
4.00
Completed Electric Flap Install
Details
07-02-2007
Electric Flaps
Details
07-01-2007
2.50
Electric Flaps
Details
06-30-2007
2.50
Electric Flaps
Details
06-28-2007
5.00
Completed Forward Covers
Details
06-27-2007
Began Forward Cabin Covers
Details
06-26-2007
Finished drilling seatbacks
Details
06-25-2007
2.50
Seat Back Assembly
Details
06-24-2007
7.00
Fabricated Seat Back pieces
Details
06-23-2007
7.00
Floors and Control Rod Tunnel
Details
06-21-2007
4.00
Finished Aft Seat Skins, F715 nutplates
Details
06-19-2007
Seat Hinge Work
Details
06-18-2007
3.00
Fwd Baggage covers and seat hinges
Details
06-16-2007
3.50
Baggage bulkhead and tunnel cover
Details
06-14-2007
F706 nutplates
Details
06-13-2007
F706 Nutplates
Details
06-12-2007
Baggage Bulkhead Fabrication
Details
06-11-2007
Baggage floor complete; started bulkhead
Details
06-10-2007
4.00
Baggage area installation
Details
06-06-2007
3.00
Attached steps to fuselage
Details
06-05-2007
Fit and drill F774 Forward Top Skin
Details
06-04-2007
1.50
Clecoed and drilled F775 Aft Top Skin
05-30-2007
4.00
Finished riveting, started Aft Top Skin
Details
05-29-2007
2.50
Riveted gussets, canopy deck pieces
05-28-2007
2.50
Primed miscellaneous parts
Details
05-27-2007
9.00
Side Rails & Canopy Decks, & Misc
Details
05-26-2007
9.00
F714 Aft Deck & miscellaneous
Details
05-25-2007
4.00
Bellcrank Support
Details
05-24-2007
6.00
Built False Spar Jig
Details
05-19-2007
Flipped the Canoe!
Details
05-12-2007
4.00
Foreward bottom skin riveting
Details
05-05-2007
4.50
Foreward Fuselage Riveting
Details
05-01-2007
Details
04-29-2007
6.00
Fuselage rivet squeezing
Details
04-21-2007
Fwd Fuselage Riveting
Details
04-20-2007
2.50
Fuselage Reassembly
Details
04-17-2007
1.50
Aft-Mid Fuselage prep for reassembly
Details
04-16-2007
Mid-Fuselage Riveting
Details
04-15-2007
4.00
Fuselage skin priming
Details
04-14-2007
6.50
Fuselage parts cleaning and priming
Details
04-13-2007
Aft/Mid Fuselage dimpling
Details
04-11-2007
3.00
Longeron and aft fuselage prep
Details
04-09-2007
Longeron Prep
Details
04-08-2007
4.00
Fuselage prep for priming
Details
03-25-2007
4.00
Foreward fuselage prep - side skins
Details
03-23-2007
Foreward fuselage prep, 7101-L replace
Details
03-19-2007
1.50
Details
03-18-2007
6.00
More prep work
Details
03-12-2007
F772 Bottom Skin Prep
Details
03-10-2007
6.00
WD-657 Step and Fuselage Disassembly
Details
03-09-2007
6.00
WD-657 External Step
Details
01-15-2007
2.50
Framed Baggage Area
Details
01-07-2007
4.50
Floor stiffener install
Details
01-04-2007
2.50
F6118 Rudder pedal brace
Details
01-03-2007
3.50
Drilled mounting holes for rudder assy's
Details
01-01-2007
7.00
Brake/rudder pedal assembly
Details
12-30-2006
3.50
Assembled brake pedals
Details
12-29-2006
5.00
Fab & Install F796B angles
12-28-2006
Fab'd all 4 F796C&D Spacers
12-27-2006
2.50
Forward bulkhead fitting
Details
12-26-2006
7.00
Lower Longeron and F-684 Gusset install
Details
12-23-2006
4.50
Installed Aux Longerons & Fwd Stiffners
Details
12-20-2006
1.50
Aux Longerons work
Details
12-16-2006
Cut holes for landing gear
Details
12-14-2006
1.50
Drilled F770 side skins to firewall
Details
12-11-2006
1.50
Firewall mounting
Details
11-25-2006
5.00
Joining Rear and Center Fuselage Assy.
Details
11-24-2006
Details
11-23-2006
4.00
Center Fuselage Joining
Details
11-22-2006
3.00
Details
11-20-2006
Details
11-19-2006
Center Fuselage Assembly
Details
11-18-2006
1.50
Finished riveting aft fuselage
Details
11-15-2006
Mid-Fuselage Assembly
Details
11-11-2006
3.00
Mid-Fuselage riveting
Details
11-10-2006
9.00
Mid Fuselage Riveting
Details
11-09-2006
7.00
Mid Fuselage Prime
Details
11-08-2006
1.50
Finished Dimpling Mid fuselage
Details
11-04-2006
8.00
Mid Fuselage Prep
Details
11-03-2006
F704 Fit and drill
Details
10-09-2006
4.00
F716 work
Details
10-08-2006
1.50
F716 work
Details
10-07-2006
3.00
Fab'd misc. parts
Details
10-02-2006
1.50
Began Riveting Aft Bottom Skin
Details
10-01-2006
3.00
Aft fuselage reassembly & riveting
Details
09-30-2006
10.00
Finish Aft Fuselage Prep
Details
09-27-2006
Aft Fuselage Prep for Riveting
Details
09-25-2006
Aft Fuselage Prep for riveting
Details
09-24-2006
Aft Fuselage Disassembly for prep
09-23-2006
7.00
Aft fuselage assembly (continued)
Details
09-22-2006
4.50
Aft fuselage assembly (cont)
Details
09-20-2006
Began Aft Fuselage Assembly
Details
09-17-2006
5.00
Finished longerons and J-chanl stringers
Details
09-16-2006
12.00
Longeron Bending
Details
09-10-2006
Longeron prep
Details
09-04-2006
4.00
Aft Fuselage Bulkhead Assembly
Details
09-03-2006
Primed Aft bulkhead pieces
Details
09-02-2006
8.00
F711&F712 Fabrication
Details
08-29-2006
4.00
F706 Fabrication
Details
08-27-2006
6.00
Bulkhead prep & 706 Bulkhead Fabrication
Details
08-19-2006
4.50
Assembled F705 Bulkhead
Details
08-18-2006
Primed F705 Bulkhead Parts
Details
08-17-2006
2.50
Prepped F705 Bulkhead parts for priming
03-30-2006
1.50
F705 Bulkhead work
Details
03-26-2006
F705 Bulkhead Work
Details
03-21-2006
6.00
F705 Bulkhead work
Details
03-19-2006
3.50
F704 Bulkhead Work
Details
03-18-2006
3.00
Rivet F704 Bulkhead
Details
03-11-2006
7.00
F704 Bulkhead work
Details
03-05-2006
6.50
F704 Bulkhead work
Details
03-04-2006
704 Bulkhead Work
Details
02-28-2006
1.50
F704 Bulkhead drilling
Details
11-12-2005
2.50
Finish wing riveting, etc
Details
11-07-2005
Finished Riveting Wing Skins
Details
11-03-2005
2.50
Wing Skin Riveting
Details
10-23-2005
Finished firewall riveting.
10-17-2005
Skin Work
Details
10-15-2005
4.00
Wing skin riveting and firewall riveting
Details
10-14-2005
1.50
Firewall work
Details
10-10-2005
3.00
Firewall work
Details
10-08-2005
3.00
Firewall work
Details
10-06-2005
2.50
Rivet on Left Bottom Inboard Skin
Details
10-01-2005
2.50
Firewall Assembly
Details
09-30-2005
1.50
Begin Firewall assembly
Details
09-26-2005
Completed Fuselage Inventory
09-25-2005
2.50
Began Inventory of Fuselage Kit
09-21-2005
0.50
Finished Dimpling Left Bottom Wing Skins
09-20-2005
8.00
Left Wing Bottom skin prep
Details
09-19-2005
5.00
Mount Left Aileron, flap hinge work
Details
09-17-2005
6.00
Finish Prep of Bottom Right Wing Skins
Details
09-15-2005
1.50
Prepping Right Bottom Wing Skins
Details
09-13-2005
2.50
Prepped Right Bottom Wing Skins
Details
09-12-2005
4.00
Various Right Wing Tasks
Details
09-05-2005
5.00
Leak Testing and Right Aileron Mounting
Details
09-04-2005
4.00
Leak Test Fuel Tanks
Details
09-02-2005
3.00
Finish right wing aileron attach. , etc
Details
09-01-2005
Prime inside of aileron pushrods
Details
08-28-2005
3.00
Aileron/Flap Attach Work (Both Wings)
Details
08-27-2005
3.50
Aileron/Flap Attachment Work (Left Wing)
Details
08-26-2005
Deburring and Aileron Bracket Riveting
Details
08-21-2005
1.50
Prepared Aileron Brackets
Details
08-20-2005
8.50
Completed Flaps
Details
08-19-2005
3.50
Flap work
Details
08-18-2005
1.50
Dimpled Flap parts
Details
08-17-2005
Flap Drilling and Deburring
Details
08-16-2005
Primed Stiffener plates
Details
08-15-2005
3.00
Flap stiffener fab
Details
08-14-2005
5.50
Flap assembly and match drilling
Details
08-13-2005
6.00
Completed Ailerons
Details
08-12-2005
5.00
Aileron Riveting
Details
08-08-2005
3.00
Finished sealing left tank....maybe
Details
08-07-2005
3.00
Finished Sealing Right Tank!
Details
08-06-2005
4.00
Fuel Tank Prep for final sealing
Details
08-04-2005
Aileron Prep
Details
08-03-2005
Debur ailerons
Details
08-02-2005
Match Drilled Ailerons
Details
08-01-2005
2.50
Tank & Aileron Work
Details
07-31-2005
5.00
Sealed Inner/Outer Ribs
Details
07-30-2005
Fuel Tank Component Work
Details
07-29-2005
1.50
Fuel Tank Work
Details
07-28-2005
Fuel Tank Sealing (Pt3)
Details
07-27-2005
4.00
Fuel Tank Sealing, Pt 2
Details
07-25-2005
2.50
Aileron Work
Details
07-24-2005
4.00
Aileron Stiffeners Installed
Details
07-23-2005
Aileron Stiffener prep
Details
07-21-2005
4.00
Sealing Fuel Tanks, Part 1
Details
07-20-2005
3.00
Fuel Tank Prep & Cleaning
Details
07-18-2005
Fuel Tank Prep
Details
07-17-2005
Fuel Tank Sealing Prep
Details
07-16-2005
4.00
Fuel Tank Prep
Details
07-15-2005
3.00
Right Fuel Tank Prep
Details
07-12-2005
Riveted Right Wing Top Skins
Details
07-10-2005
1.50
Rt Tank Fuel Level Sensor Work
Details
07-09-2005
4.50
Rt Tank Inboard Rib Prep
Details
07-08-2005
Rt Tank Rib Stiffeners
Details
07-07-2005
Right Fuel Tank and Wing Work
Details
07-06-2005
1.50
Finish Rt Wing prep for riveting
Details
07-05-2005
Dimple Right Wing
Details
07-04-2005
3.50
Right Wing Deburr/Dimple
Details
07-03-2005
8.00
Right Leading Edge Finish, Spar Work
Details
07-02-2005
5.50
Prep Right Leading Edge for Riveting
Details
06-30-2005
4.00
Details
06-28-2005
2.50
Prepare Rt Fuel Tank Z-brackets
Details
06-27-2005
2.50
Right Wing and Fuel Tank Work
Details
06-26-2005
4.50
Right Wing / Leading Edge Work
Details
06-25-2005
4.50
Rivet L Top W Skins, Put R Wing on Stand
Details
06-24-2005
0.50
Deburr Wing Skin
Details
06-23-2005
1.50
Prepare Pitot Mast
Details
06-22-2005
3.50
Rivet Left Leading Edge
Details
06-20-2005
3.50
Left Wing Top Skin Prep and Mount
Details
06-19-2005
4.00
Left Wing Upper Skins prep
Details
06-18-2005
Prep rear spar to skin holes
Details
06-16-2005
Left Wing Skeleton Deburr/Dimple
Details
06-15-2005
CS Front spar for skin dimples
Details
06-14-2005
2.50
Left Leading Edge Finished, etc
Details
06-13-2005
Left Leading Edge Riveting
Details
06-12-2005
4.00
Left Leading Edge Prep for Riveting
Details
06-10-2005
4.00
Left Fuel Tank Prep
Details
06-09-2005
Deburr left wing upper skins
Details
06-08-2005
1.50
Cut T711 stiffeners
Details
06-06-2005
3.50
Left Fuel Tank Prep continued
Details
06-05-2005
2.50
Fuel Tank skin prep
Details
06-04-2005
6.00
Left Fuel Tank Fitting
Details
06-03-2005
5.50
Left fuel tank attach Z-brackets
Details
05-30-2005
3.00
Leading Edge Assy (left wing, pt 2)
Details
05-27-2005
4.00
Leading Edge Assembly (left wing)
Details
05-25-2005
Finish Match Drilling Left Wing Skins
Details
05-24-2005
2.50
Match Drilled Left Wing Top Skins
Details
04-17-2005
4.00
Primed Ribs
Details
04-16-2005
4.00
Prepped Ribs for priming
Details
04-06-2005
Corrected Left Spar Manufacturing Flaw
Details
04-05-2005
Deburred Wing Ribs
Details
04-04-2005
Debur Ribs
Details
04-03-2005
2.50
Conduit Holes
Details
03-30-2005
3.00
Drilled Wing Skeletons
Details
03-28-2005
Clecoed Right Wing Skeleton
Details
03-14-2005
3.00
Complete Front/Rear Spar assembly
Details
03-12-2005
10.00
Rear Spar Assembly/Priming
Details
03-11-2005
Rear Spar Assembly
Details
03-10-2005
3.00
Prep rear spar pieces
Details
03-06-2005
2.50
Assembled Wing Tiedowns
Details
03-05-2005
4.00
Fabricated Wing TieDowns
Details
03-02-2005
More spar nutplates
Details
03-02-2005
2.50
Front Spar Prep
Details
02-28-2005
1.50
CS tank attach screw holes
Details
02-27-2005
5.00
Tank skin platenuts
Details
02-26-2005
5.00
Built Wing Cradle
Details
02-22-2005
Inventory Completed
Details
02-19-2005
2.50
Inventory Continued
Details
02-18-2005
1.50
Began Inventory
Details
02-05-2005
4.00
Finished Elevators
Details
01-29-2005
6.00
Elevator Finishing
Details
01-22-2005
7.00
Completed Trim Tab (1 exception!)
Details
01-20-2005
Trim Tab Prep
Details
01-19-2005
1.50
Trim tab prep
Details
01-18-2005
2.50
Rivet L Elevator skin
Details
01-17-2005
5.00
L. Elevator prep and riveting
Details
01-16-2005
8.00
Close elevator at trim tab cutout
Details
01-15-2005
Prep Elevator Trim parts
Details
01-02-2005
3.50
Right Elevator riveting
Details
01-01-2005
3.00
Elevator priming and riveting
Details
12-25-2004
Left elevator prep
Details
12-24-2004
1.50
Left Elevator prep
Details
12-23-2004
Dimple Right Elevator
Details
12-22-2004
3.00
Right Elevator assembly prep
Details
12-20-2004
Elevator Skins drilled
Details
12-19-2004
1.50
Elevator Skeleton work
Details
12-16-2004
2.50
Elevator skeleton prep
Details
12-13-2004
Back Rivet Elevator Skins
Details
12-12-2004
Rudder Complete
Details
12-12-2004
1.50
Dimple Elevator Skins/Stiffeners
Details
12-11-2004
4.50
Rudder Riveting
Details
12-08-2004
1.50
Elevator Stiffeners
Details
12-07-2004
Elevator Stiffeners
Details
12-06-2004
Cut Elevator Stiffeners
Details
12-05-2004
4.50
Rudder Riveting
Details
12-05-2004
1.50
Rivet Rudder Skeleton
Details
12-04-2004
4.50
Rudder Riveting
Details
12-01-2004
Rudder Work
Details
11-29-2004
2.50
Rudder Prep
Details
11-27-2004
3.00
Rudder assembly and deburr
Details
11-26-2004
3.50
Assemble rudder skeleton
Details
11-25-2004
5.00
Finish rudder stiffener/skin work
Details
11-24-2004
3.00
Dimple Rudder Skins
Details
11-20-2004
1.50
Drill Rudder Stiffeners
Details
11-19-2004
Trimmed Rudder Stiffeners
11-17-2004
3.50
Completed VS
Details
11-16-2004
3.00
Rivet VS skeleton
Details
11-14-2004
Primed VS parts
Details
11-13-2004
5.00
VS prep work
Details
11-11-2004
3.50
dimple, CS VS parts
Details
11-09-2004
3.00
Drilled and Deburred VS parts
Details
11-08-2004
1.50
Drilled VS skeleton
Details
11-07-2004
Cleco'd rear VS, prepped ribs
11-06-2004
6.00
Finished HS
Details
11-05-2004
3.00
Finish riveting left HS
Details
11-04-2004
Rivet HS707 left to skin
Details
11-03-2004
Riveted the HS-707s (top)
Details
11-02-2004
HS riveting
Details
11-01-2004
Rivet HS Rear Spar
Details
10-31-2004
2.50
Primed HS parts
Details
10-30-2004
Cleaned/Etched HS parts
Details
10-30-2004
2.50
Built etching/painting jigs
Details
10-29-2004
2.50
Dimpled HS skins, edge finishing
Details
10-28-2004
2.50
HS Dimpling
Details
10-26-2004
2.50
Deburr HS parts
Details
10-24-2004
3.50
Drilled HS, Right Side
Details
10-23-2004
5.00
Drill HS, Left side
Details
10-22-2004
2.50
Finish HS ribs prep
Details
10-20-2004
Trim HS404 Flanges
Details
10-19-2004
5.50
Front Spar Assembly
Details
10-18-2004
1.50
Asmble HS-411; Fin HS R Spar Prep
Details
10-17-2004
2.50
Match drilled HS rear spar
Details
10-16-2004
4.00
Prep HS Rear Spar Stiffeners
10-15-2004
3.00
Inventory Empannage Kit
