Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Kurt Haller
  Pleasanton, CA - USA
Aircraft:
  Vans RV-9A
Total Build Hours:
  2838
Web Site:
  http://www.mykitlog.com/khaller/
Date:  09-02-2019
Number of Hours:  0.00
Short Description:  Flight number 2
While putting in the backup EFIS, also installed a RAC speed controller for both trim motors. It's basically a linear voltage regulator (instead of a PWM H-bridge) but it's simple and light. I drew up a circuit to feed +voltage from either the forward or reverse lines power lines to the trim motors through two diodes a and pull-down resistor. The SV-EMS C37P20 and P21 lines were set as contacts. When the motors are not moving, the voltage is 2.5, and when moving in either direction, the voltage is 5V. Plenty of margin for a contact light on the EMS screen to light up when the motor is moving. Would be cool if the Dynon could throw an alarm if motors were on longer than 3 sec.
With Barry in Australia, took her up all by myself and repeated test flight 1--without the computer glitches thank you very much. A few issues along the way: a) left hat at home; b) tried to start with tank selector OFF; c) turned off both mags during run up; d) took off with flaps down; e) did not use boost pump for t/o or landing. CHT's got above 400 because I could barely climb at 100 KIAS until I noticed the damn flaps. Boy, takeoff was like an elevator--200 ft+ above the runway in no time. On the good side, worked up to 130 KIAs (75% power, CHTs well below 400) and down to 65 KIAS on fast and slo flight test points. For landing, intercepted a long 4-5 mi straight in to 25R. Was right on 70 KIAS for last 2 miles, and landing was a breeze, maybe a tad of side load, but nose gear was off the pavement until full up elevator couldn't keep it off.
8PK waiting for go-gas...
 Recent Builder Activity
Builder Project Date Hours
Des Howson
Sling 2 Taildragger
05-25
2230
Andrey Piskarev
Highlander
05-24
1228
Chris King
Fokker D.VII
05-24
1568
James Roberts
RV8
05-24
76
Peter McBain
RV-9A
05-24
1468
Phil Risley
RV9
05-24
1084
Rick McBride
RV-10
05-24
1597
Robert Lussow
RV-10
05-24
2603
Thomas Ferranti
RV7
05-24
211
David Lewis
RV10
05-23
2477
Jay Johnson
CH-750 Cruzer
05-23
1934
Taran Laval
RV-7
05-23
462
Terry Smith
Vortex
05-23
116
Anthony Jolly
RV-7
05-22
178
Brian Perry
RV-14a
05-22
694
Carl Orton
750 Cruzer
05-22
591
Darrel Watson
S7 Super Sport
05-22
1835
James Chadwick
RV-7
05-22
382
John McGlynn
S-19
05-22
255
John Peck
C120
05-22
330
Martin Filiatrault
RV-8
05-22
2592
Norris Brown
RV10
05-22
1142
Peter Calley
Sling4
05-22
2160
Lauren Voigt
S7 STi
05-21
180
Mark Weitkamp
CX4
05-21
1556
Bob Corriveau
RV-8
05-20
1610
James Anderson
Larcair ES
05-20
3279
Ronald Cardwell
RV-8
05-20
796
John Nate
Defiant
05-19
600
Lance W. Miller
CH650
05-19
181
Projects Uploaded: 1482
Logs Uploaded: 258095
Copyright © 2001-2020 Matronics. All Rights Reserved. Privacy Policy.
