Previous Builder
Next Builder
Date: 05-07-2016
Number of Hours: 3.00
Short Description: Aileron connections
Finished bolting all of the aileron push rods to their respective bearings. Then re-installed the ailerons and cut the aileron bellcrank to aileron hinge tube (1/2" x 0.035"). I added the adjustable bearing to one end (as per change notes to the original plans). This will allow that little extra adjustment in the aileron system if required. Also, trial fitted the aileron slave strut (from bottom to top aileron). Will need some heating and bending before welding.
Aileron push tube
Top connection of aileron slave strut
Bottom of slave strut - needs some work!
Previous Builder
Next Builder
