Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Michael Garmon
  Manvel, TX - USA
Aircraft:
  Mk IV
Total Build Hours:
  3556
Web Site:
  http://www.mykitlog.com/garmonm/
Date:  09-04-2022
Number of Hours:  10.00
Short Description:  Routing and Rigging the Rudder Cables
The left rudder was rigged up using the compression spring between the rudder pedal connection and the Instrument Panel. A connector with a removable pin is used to connecte the cable from the pulleies to the cable as it enters the wing.
The right rudder has a problem. The conduit had some pluggage or had been squeezed. Probably when the arm rest was installed. A new conduit was run through the electrical conduit. It was securred at both ends. It has been rigged in a similar fashion as the left.
There are still some rigging issues on both sides. Neither one will reach the full 4 to 4.5" before contacting the break actuator. It has been recommended by many on the Cozy Mailing list to make sure that there is a 2.5:1 lever on the brake actuator. It does not currently have that even at the most extreme location. This must be corrected before this step is completed.
 Recent Builder Activity
Builder Project Date Hours
Jean Gosselin
RV6
04-24
2669
Michael Smith
RV-7
04-24
696
Adam Grosser
RV-7A
04-23
825
Andrey Piskarev
Highlander
04-23
3812
Bob Corriveau
RV-8
04-23
4165
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
04-23
2046
Michael Sausen
RV-10
04-22
1513
Chuck Bennett
Sonex-B Tri-Gear
04-21
1152
Johann
TSI
04-21
914
Mark Johnson
RV-10
04-20
490
Barry Wawrin
RV14A-QB
04-19
2379
Paul Minelga
Bearhawk
04-17
4222
Jim Novak
RV-8
04-14
3159
Peter McBain
RV-9A
04-13
2120
Darrel Watson
H-5
04-12
457
Peter Calley
Sling4
04-11
2305
Sven Hollenbeck
RV-8
04-08
70
Wendell Engelien
RV-6A
04-04
2354
Mark Spedding
COZY MK IV
04-01
3463
John McGlynn
S-19
03-30
346
Des Howson
Sling 2 Taildragger
03-25
3606
Marlin Sander
RV-7A
03-25
5652
Edward Beam
RV-14A
03-22
1304
Gary Smith
RV-10
03-22
2863
Jack Clark
RV-14A
03-22
604
Tony Batchelar
RV6
03-17
Alex KOLLEP
Sportsman 2+2
03-15
1656
James Chadwick
RV-7
03-14
748
JAMES TRAYNOR
VELOCITY- XLRG
03-11
2528
Andrew Duff
Nexus Mustang
03-09
2943
Projects Uploaded: 1549
Logs Uploaded: 283982
Copyright © 2001-2024 Matronics. All Rights Reserved. Privacy Policy.
