Home
Builder Search
Builder Login
KitLog.com
RECENT ACTIVITY
Previous Builder          Next Builder
Builder:
  Joseph A Nelsen
  Gunter, Tx - USA
Aircraft:
  NELSEN SONEX
Total Build Hours:
  1349
Web Site:
  http://www.mykitlog.com/JosephNelsen/
Date:  12-21-2017
Short Description:  engine heater
As time goes by, I have been busy, and have forgotten to take pictures of my intall of an oil filter system. However, the next time I have the cowl off I will try to remember to take pictures. MY bad!!
1) In my own defense, I did take pictures of the engine preheater system. It is using the same heater element I had for the 172 for years. The initial device was intended to mount in a household heating duct outlet for auxillary heating. Originally it was thermostatically controlled, but that was bypassed as it would not get hot enough with the added ducting. When on the 172, there was no ducting and the freeflowing output air was enough to keep things happy, thermostat wise. this picture shows a thermometer inserted into the outlet, and it usually runs just shy of 170 deg. Plenty hot to make the fiberglass quite warm...as if the engine just was shut doen after a nice flight.
Anyway, the heater was made to satisfy me about preheat on cold days. I have yet to configure it to also blow into the oil cooler to actually warm oil, but since I do have several openings into the crankcase, I need to investigate the possibilities of using a temp controlled dip stick,
The next projects is to change the small tires for 500x5 tires, and finish fabrication on the improoved rudder/tailwheel linkage using heim ends.
The last flight was using TCP fuel additive for lead scavangeing, as I have had some on #3 exhaust valve already. I also used it on the Cessna and like it for what it does.
heater with tem p gauge
LH side
overall
 Recent Builder Activity
Builder Project Date Hours
Bob Corriveau
RV-8
04-24
4168
Jean Gosselin
RV6
04-24
2669
Michael Smith
RV-7
04-24
696
Adam Grosser
RV-7A
04-23
825
Andrey Piskarev
Highlander
04-23
3812
Bob Grantham
SeaRey LSX - "Spirit of Mackenzie"
04-23
2046
Michael Sausen
RV-10
04-22
1513
Chuck Bennett
Sonex-B Tri-Gear
04-21
1152
Johann
TSI
04-21
914
Mark Johnson
RV-10
04-20
490
Barry Wawrin
RV14A-QB
04-19
2379
Paul Minelga
Bearhawk
04-17
4222
Jim Novak
RV-8
04-14
3159
Peter McBain
RV-9A
04-13
2120
Darrel Watson
H-5
04-12
457
Peter Calley
Sling4
04-11
2305
Sven Hollenbeck
RV-8
04-08
70
Wendell Engelien
RV-6A
04-04
2354
Mark Spedding
COZY MK IV
04-01
3463
John McGlynn
S-19
03-30
346
Des Howson
Sling 2 Taildragger
03-25
3606
Marlin Sander
RV-7A
03-25
5652
Edward Beam
RV-14A
03-22
1304
Gary Smith
RV-10
03-22
2863
Jack Clark
RV-14A
03-22
604
Tony Batchelar
RV6
03-17
Alex KOLLEP
Sportsman 2+2
03-15
1656
James Chadwick
RV-7
03-14
748
JAMES TRAYNOR
VELOCITY- XLRG
03-11
2528
Andrew Duff
Nexus Mustang
03-09
2943
Projects Uploaded: 1549
Logs Uploaded: 283983
Copyright © 2001-2024 Matronics. All Rights Reserved. Privacy Policy.
