Previous Builder
Next Builder
Date: 02-16-2018
Number of Hours: 4.00
Short Description: Troubleshooting
Today, I found the problem. It was in the PTT switch where a wire was pinched due to a screw that was holding the two halves of the stick grip together. Everything tested ok. I replaced everything, and tested each time I buttoned something up. Everything now works. It will be interesting to see if my trim light LED indicator was sensitive to the radio ground.
Finally, I removed the #1 valve cover, but in the process of trying to stop the leak, we had tightened the bottom screw too tight and it snapped coming out. So, now I have to remove a partial screw from the head. We'll try an extractor tomorrow. Hopefully it was the pressure of the head and not the threaded body that was working against me.
Previous Builder
Next Builder
