![](/users/templates/images/spacer.gif)
![KitLog pro](/users/templates/images/baron/header_logo.gif)
Zenith CruZer & Sonex Logs
![' style=](/users/templates/images/spacer.gif)
Date: 3-19-2018
Number of Hours: 2.80
Manual Reference: C75-WA-1
Brief Description: Skeleton Rivet / Spar Debur & Rivet
First up was to complete riveting the nose and rear ribs to the main spar using A5 rivets.
Next, I had a few A6 (BIG!) rivets on each end. Two A6's hold the root rib nose and rear ribs; had to ream the holes for the rivets to go through.
Next, the upper and lower rows of rivets holding the spar tip extension in place required A6's. Again, I had to use a chucking reamer to ensure the holes were the correct size.
After that, I attached the two L-angles on the main spar and rear spar that will hold the fiberglass wingtip in place. This took A4 rivets. That completed the basic skeleton.
Next I took some time and thoroughly deburred all aft spar components. The aft spar, due to length, comes in two parts - inner and outer. They are joined with a splice plate. Additionally, the inboard section of spar has upper/lower doubler angles the full length, as well as a 1/8" thick plate backer the first 10" (guessing) of the inboard spar.
After cleaning up all parts, I cleco'd everything together. I noticed an issue with the pre-drilled splice doubler channel preventing correct mating, leaving gaps between parts to be riveted. I've contacted Zenith about this issue. so only riveted the inboard spar components.
Inboard rear spar ready for riveting
Big A6 rivets holding root rib
Big A6 rivets (top and bottom rows)
