Made up a fix for the missing metal on RR9 and some small angles for the bottom leading edge of the rear ribs. I just want to make sure the rivets have good metal to pull the lower bottom rear rib to the spar angles. Made up some small .025" x 1.1" x 1" x 1" angles to rivet to the webs at the joggle. Deburred and installed on all left rear ribs with 3/32 clecoes.
Mixed up 6oz of primer for the air brush. Taking all left ribs, all nose ribs, spar tips to work to use the spray booth tonight.
